How to fix a low battery voltage?
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
LinkBack (1) Thread Tools
Old January 3rd, 2009, 09:52 PM   1 links from elsewhere to this Post. Click to view. #1
1991 Mustang GT
Shawnsac2000 is on a distinguished road
Hello, I just bought a 1993 Ford Mustang LX 2.3L i replaced the battery and the alternator. And the battery voltage meter on the dashboard is low, and the battery light is staying on. I took back the alternator to pep boy's to replace it and they checked my battery. They gave me another alternator i hooked it up and its still doing the same thing. If i turn on the head lights the battery voltage meter drops. What else could be causing this? Thanks!
Old January 3rd, 2009, 09:55 PM   #2
MMs Ford Racing Nut Swinger
1FUN4RD's Avatar
2007 MUSTANG GT
1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold
A weak ground
www.1fun4rd.blogspot.com
Old January 3rd, 2009, 10:10 PM   #3
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
Originally Posted by 1FUN4RD View Post
A weak ground
+1. Check to make sure your ground location is clean and the bolt is tight.
Old January 3rd, 2009, 10:30 PM   #4
1991 Mustang GT
A weak ground
On the battery?
Old January 3rd, 2009, 10:37 PM   #5
1FUN4RD's Avatar
2007 MUSTANG GT
Originally Posted by Shawnsac2000 View Post
On the battery?
No, the other end of the cable. Also check the ground strap that goes from the engine to the frame.
Old January 3rd, 2009, 11:16 PM   #6
1991 Mustang GT
I will check it out tomorrow, thanks!
Old January 3rd, 2009, 11:18 PM   #7
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
Breakout is a jewel in the roughBreakout is a jewel in the roughBreakout is a jewel in the rough
Send a message via AIM to Breakout
is there a lot of corrosion?
Old January 3rd, 2009, 11:25 PM   #8
1991 Mustang GT
no
Old January 4th, 2009, 11:08 AM   #9
1991 Mustang GT
I fixed it the green wire that connects to the starter relay was burnt, its running good now.
Old January 4th, 2009, 01:28 PM   #10
1FUN4RD's Avatar
2007 MUSTANG GT
Glad I could help
Old January 5th, 2009, 04:34 PM   #11
SpeedSicks's Avatar
'79 2.5 Turbo Stang Coupe
Working on it...
SpeedSicks is on a distinguished road
Send a message via MSN to SpeedSicks
glad to hear its running good, but for future reference the current could be affected even if the wires/connectors look clean (i.e. no corrosion).
but after a while, sometimes only a few months, a gray shiny layer can form between the terminal and the inside of the cable connector. i'm sure you've seen it before.
it can be very hard to notice cuz it looks normal, and not corroded! i suggest either wire brushing both peices every-other oil change, or sometime i've seen it bad enough that you need to scrape the layer of the connector away with a knife to restore full current.
it can extend battery life, alternator life, and save you from a no start/no charge issue. all cars can do it, but cars with more electronics tend to build up faster.
1979 MUSTANG COUPE: 2.5T BLOWTHRU CARB
Old February 1st, 2009, 08:47 AM   #12
87MustangLX is on a distinguished road
Hi everyone new member here my 87 Mustang is doing the same thing the voltage meter is fine until you cut on the heater and then the voltage drops almost to red when your putting on brakes could same thing be wrong with mine if so where is the starter relay on a 2.3 Mustang
Old May 26th, 2011, 12:34 AM   #13
Look Ma! My First Post!
bathmarm0t is on a distinguished road
@speedsicks
would putting a dab of dielectric grease on the battery terminals help against the corrosion?
Old May 26th, 2011, 12:47 AM   #14
Cgross609's Avatar
93 Mustang LX 2.3 T-5
Cgross609 is on a distinguished road
It sure would. A common practice at most/some dealers is to spray a layer of laquer or brand name "Fluid Film" which is basically just a type of non-evaporating lubricant, on the battery terminals/relay connections. It stops rust for quite a while surprisingly. Go to your local farm equipment store. They sell fluid film. Lol.
93 2.3l LX
U.S. 15x7 ten hole rims
Calypso green
Moates QH
T-5 Conversion
Dual 2.5" Exhaust with Thrush Welded muffler
Old May 26th, 2011, 10:06 PM   #15
clash69's Avatar
88 vert 2.3t verbo
clash69 is on a distinguished road
87 mustang starter relay on drivers wheel well, strut tower near battery all fox body 2.3 had weak charging systems that is why the upgrade to 3g 130amp alternators
Old May 28th, 2011, 01:20 AM   #16
1991 Mustang LX 2.3
zonker is on a distinguished road
another item to check is the connectors at the alternator itself. loos or corroded connectors there will give bad alternator voltage outputs and could even start an electrical fire.
best bet is to clean them up well and then coat the connector with dilectric grease prior to plugging it into the alternator.
Rob
1987 Mustang 2.3 LX Convert (T5) project 2.5 N/A HP
1991 Mustang 2.3 LX Convert (A4LD)
1992 Mustang 2.3 LX Convert (A4LD) 41.52 mpg!!
1994 Capri XR2 1.6 Turbo Convert
1999 ZX2 S/R 2.0 Coupe
http://zxtuner.com
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2-3-mustangs/103900-how-fix-low-battery-voltage.html
Thread Low battery voltage | Corvette C6 - C1 Reviews, Performance, Parts for Sale | BoardReader This thread Refback July 19th, 2011 04:37 PM
Threads Similar to: How to fix a low battery voltage?
what low fat/low carb foods give energy vfast The Clubhouse 23 November 18th, 2008 08:25 PM
Low Profile Tire Series, How Low Is Too Low? Steam V6 Mustangs 11 November 11th, 2007 12:48 AM
battery Voltage new 5.0 94-95 3 June 19th, 2007 09:38 AM
Low compression and low Octane? brad65 5.0 Mustangs 5 July 28th, 2006 04:53 PM
