blow through carb
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
LinkBack (4) Thread Tools
Old January 19th, 2009, 12:26 AM   4 links from elsewhere to this Post. Click to view. #1
lostchild is on a distinguished road
blow through carb
so im building my 2.3 n/a up for the turbo, (pistons, head work, valves, etc etc etc.) im shooting for like 300 or 350 hp. what size carb should i use? i know that i need a blow through carb. just dont know how many barrels and cfm's? i dont want to do fuel injected (im fond of old school stuff)
Old January 19th, 2009, 06:21 PM   #2
MSO
MSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the rough
Send a message via AIM to MSO
this may sound like a kick to the nuts, but the factory carb'd 2.3Ts were horrible. i doubt there's a lot of people around that know anything about carbing a 2.3T
[SIGPIC][/SIGPIC]
Old January 20th, 2009, 05:34 PM   #3
SpeedSicks's Avatar
'79 2.5 Turbo Stang Coupe
Working on it...
SpeedSicks is on a distinguished road
Send a message via MSN to SpeedSicks
nope not many, you should try turboford.net. if you search there you will find enough information to decide. a v8 motor outputting that much horsepower would use a 350, or 500 cfm. so your motor would as well. you can run either a 2 barrel or a 4 barrel. your choice. alot of ppl run a 4 barrel so you don't have to run a 2 brrl rich at idle, in order to not run lean at WOT.
but that doesn't mean you have to, if tuned properly it wont matter. you will be able to achieve that horsepower. a kid i know of runs a 350 holley 4 brrl, and runs 332 whp with a simple setup.
you do know that you can't just run a carb in a blow thru, and expect it to hold the PSI. solid floats must be used, as well as any holes sealed up to hold pressure. choke removed. etc, google it. there are DIY instructions for holley carbs to convert.
1979 MUSTANG COUPE: 2.5T BLOWTHRU CARB
Old January 20th, 2009, 05:35 PM   #4
SpeedSicks's Avatar
Working on it...
i had a factory carbed 2.3 turbo, it ran fine for yeeeeears! the main problem was they didn't have an intercooler cuz they were draw thru! but you can add one easily with blowthru good luck.
it will run better blowthru than the drawthru did, but really for how old they were..with a turbo..they ran great..better than the 5.0s at the time.
Old January 22nd, 2009, 07:07 PM   #5
blow through
whats the diff between draw through and blow through and why cant you put a intercooler on a draw through?
Old January 23rd, 2009, 09:55 AM   #6
Authorized Vendor
Matt Cramer's Avatar
Matt Cramer is on a distinguished road
Draw through setups have the carb mounted to the turbo's intake. Since you have a fuel / air mixture coming out of the turbo, running it through an intercooler can make the fuel drop out. And you definitely would not want to find out what happens if a rock hits your intercooler and puts a hole in it.
Old January 25th, 2009, 09:06 AM   #7
MSO
I'd stick with EFI for a 2.3T.
I don't really see the advantage of a carb'd one.
[SIGPIC][/SIGPIC]
Old February 4th, 2009, 06:02 PM   #8
1988 Mustang LX coupe
8notch8 is on a distinguished road
well, heres my two cents...i know alot of the dirt track guys running 300+ in n/a form are using holley 350cfm, but with boost you could possibly run a 500 or 600 cfm if you monitor the a/f ratio (o2 sensor) and jet accordingly. If you are carefull you could also use the 350 under boost. This sounds familiar to a concept I was considering...but I was thinkin about 600+ hp with boost.
Old February 25th, 2009, 07:00 PM   #9
SpeedSicks's Avatar
Working on it...
use a holley 350 2 brrl for that HP range. talk to Ford Racer on turboford.net for more info on a working setup with blow thru holley.
i use a custom built 4 brrl 390 carb, so... if you have money i can help a little lol.
Ford Racer made 332hp with that holley 350 though...he may even sell it(and its already set up for blow thru). cuz he was thinking of upgrading to a 500 holley to see what would happen.
good luck, you should really try turboford.net. you will get more help then here
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2-3-mustangs/106261-blow-through-carb.html
mightyram50.com • View topic - What carb to blow thru? This thread Refback November 11th, 2010 12:23 PM
mightyram50.com • View topic - What carb to blow thru? This thread Refback April 5th, 2010 04:43 PM
mightyram50.com • View topic - What carb to blow thru? This thread Refback March 5th, 2010 03:16 AM
mightyram50.com • View topic - What carb to blow thru? This thread Refback August 30th, 2009 02:27 AM
Threads Similar to: blow through carb
Blow This! TheUNZippee! The Clubhouse 44 October 7th, 2009 12:11 PM
Carb Hat/Bonnette for Blow Through thumper_302 All Other Vehicles 0 August 13th, 2008 01:36 AM
Blow-by!?! timeformiller44 99-04 13 June 5th, 2008 02:55 AM
blow off mystang0673 99-04 0 August 30th, 2007 10:26 PM
Blow By jj2473 5.0 Mustangs 7 July 14th, 2007 11:32 PM
