1993 mustang lx 2.3
havnt ran yet
Front end shake
hey ive noticed that recently that the front right of the stang shakes i think it make be the tie rod end or could it be just because it out of alignment i feel more vibration in the steering wheel any way because of have no rag joint of rag joint eliminator just bolts holding it together lol thats another questions where can i get a rag joint for it?
are you sure your tires are balanced and your rims arent bent.if you have bad tie rods your car will shake like a shopping cart with a F ed up caster
meh
You can get those rubber rag joints at any auto parts store.. As far as your steering shaking, does it always do it, or is it only while applying the brakes?
If its only while hitting the brakes, you need to get your front rotors turned, or replaced. If you have a tire out of balance or a bent rim, it will constantly shake and wear the tie rod end(s) out faster than normal... if thats been the case for a while and you just put new tires and balanced them, but left bad tie rod ends on it, any small bump might set the wheel in a shake, since the tie rod end is bad. The best way to know for sure is to check it.. jack it up, block the back wheels and put the front on jackstands. Then get someone to turn the steering wheel a little. Watch the tie rod ends and the wheels, to see if the tie rod moves but the wheel doesnt. (slack in the tie rod end) After that, you can try grabbing each front wheel at 3 o'clock and 9 o'clock and give it a shake back and forth to check for play. You might have more play in one wheel than the other.
'87 2.3 Notch with +4 cylinder mod ![]() Ass, Cash, or Grass.. nobody rides for free Black Stang Crew Member #11 |
1993 mustang lx 2.3
havnt ran yet
i feel it in the steering wheel i think its because i have no rag joint and the alignment is off i would not be suprised if it was the brakes my back left shoe is cracked. but my rag joint will be fixed tomorrow so i may loose some of the shake.
an alignment wont cause a car to shake
1993 mustang lx 2.3
havnt ran yet
i worded it wrong the steering wheel shakes.
97 single port w/bolt ons
n/a
sounds like a belt in the tire is /has slipped .{outa round} you can jack it up and spin it fast to see if there is a high spot or take it to a shop of ur choice. i work at a tire shop and it sounds like a broken belt. my 2 cents
![]() bolt ons for now..... split port swap very soon.... |
1993 mustang lx 2.3
havnt ran yet
k thanks for all the input. i think i got a prob with the u-joints it kinda wobbles between 55-65 then when you get past that it smooths out im going down to my buddys shop thurs so ill check all that stuff out once again thanks for all the input
Check the tires and rims.
Mustang GT 1996 Mustang Accessories |
I know this is an old thread but what was the resolution if any?
2002 GT - CAI, Full Bassani Exhaust (Headers to tail pipes), SCT Tuner (X3) - No Track Time 1989 GT - 434, C4, 9 inch rear with 4.56s, N/A - Its kinda fast ![]() 2006 Silverado 2500HD 6.6L Stump Puller (Stock) |
Threads Similar to: Front end shake
| Back end sitting lower than front end? | Blown 97 GT | 96-98 | 31 | October 21st, 2009 03:45 PM |
| front end- again | zmaier | 96-98 | 1 | September 14th, 2008 09:26 PM |
| a lot of rear end shake on my cobra!! | 006leenstang00 | 4V / SVT | 30 | February 22nd, 2008 03:31 PM |
| my front end | justinsstang | General Tech | 7 | February 8th, 2008 11:30 AM |
| Front End, Shimmy Shake | tlwoody | 94-95 | 5 | November 6th, 2006 02:17 PM |
