1988 lx t-top
Any 4 Cyl To v8 Conversion Questions?
questions on 4 to 8 conversions?
I converted my fuel injected 4 banger to a carbed v8 if any one has any questions on how to do it or what parts to use just post tyour questions and i did it as cheap as possible |
1999 Ford Mustang V6
are you asking if anyone has questions, or if anyone has done this yet?
i think hes saying he just did it and he is offering to help anyone who may want to try too
how much was it to accomplish and what all needed to be replaced?
I have a 1990 2.3 thats begging for the conversion. thank you |
1988 lx t-top
didnt keep track and i got a lot of free stuff and it depends on how far you want to convert
#6 | |
1988 lx t-top
thats how i would do it
Yes, I am doing this now
Questions:
Can I take the airbag out of my 90 LX and use it in the 89 4 cyl? What do I need as far as wiring? I am also taking the dask from the LX and transfering it to the 4 cyl I am going to use the v8 air cond? What do I need to do? So far I have changed the rear, what about rear brake lines, I see they are in 2 different locations, I guess I just run some replacement lines to the different fittings? |
I have some questions, of course I have and will continue to search.
I have a 87 convertible 5spd, with a 2.3L but I have a 302 from a 85 Thunderbird. I was wondering if the tranny from the 4cyl would fit the 302. "I know that it would be recommended to get one from a V8 mustang but I haven't had any luck finding one. Also would I have to get different engine mounts for the 302?? What kind of aftermarket fuel management options are there for an 87?? Is it possible to get my current ECU chipped/modified to run the 302?? |
Hey..I just bought my first car...A 1989 Mustang LX. It currently has a 2.3 4 cyl..Took me a while but I found a 5.0L OH 302..I want to convert, problem is I don't know much about these engines, or where to start =o\ The guy I bought the engine from threw in the rad, computer and harness, and drive shaft...they're all from a 86..
Any help or advice would greatly be appreciated!!! |
i have a 91 fox body and want to convert to a 5.0. what all do i have to change to body and frame to accomplish this.?Also what other mods. to the suspension will i need?
Look Ma! My First Post!
hi new to this site converting a 1988 4cy to a v8 302 bought a 89 body with a v8 freshly removed took my v8 out of my converted 81 lx motor mounts will not work what could the problem be are there differetn mtr mounts that i need or do i have to drillholes the 81 88 holes seem to be further apart then the 81 need hel
#13 | |
1988 Mustang LX Turbo
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
the 2.3 to a 5.0 is the worlds most popular swap
gotta change motor mounts, rear ends, power steering rack, wiring harness if your going EFI, stiffing the subframe, i know theres more but this is pretty much it
is it that bad 2 convet 5 2 a 8 carb
I just bought a 86 coupe (4cyl of course) and I'm planning to put a 347 carb. in it. this will be a drag only car. how much trouble am I looking at? any tips? by the way its an A.T. any help would be appreciated
hi
hey, I have an 88 lx 4banger I'm in the middle of swapping it with a 5.0 from an 87, (both EFI) I feel I'm making good progress with all the parts I have laying around, but want to make sure everythings right the first time! anyone know a website that might have a guide to these conversions?
Thanx |
Threads Similar to: Any 4 Cyl To v8 Conversion Questions?
| help with 2.3L to 302 conversion | superls92 | 5.0 Mustangs | 19 | June 25th, 2010 10:09 AM |
| 5 lug conversion | notsoslo5.0 | 5.0 Mustangs | 8 | February 6th, 2007 07:26 PM |
| 302 to 306 conversion | craigkoz00 | 94-95 | 1 | January 2nd, 2007 11:46 AM |
| 5.0 conversion | 03stanger | 5.0 Mustangs | 4 | June 29th, 2006 07:38 PM |
| 4 lug to 5 lug conversion questions | jharp59 | Classic Mustangs | 0 | June 10th, 2006 10:44 PM |
