84 Turbo GT
Erratic Idle
Hey guys I have a question I have a 84 mustang with the 2.3l Turbo motor in it. I just bought it and did a tune up on it over the weekend. (new plugs, wires, cap, rotor, oil change, fuel filter). My problem is when I start the car it revs up to about 1500 RPM's then slowly goes down, then it fluctuates, like it doesn't know where to idle at. Also when I drive it, it hessitates and jerks like its not getting fuel. I have no clue whats wrong with it. I have no problem reading or searching for this stuff, I just have found nothing about it other then maybe the EGR valve is bad. So please if you know of any post please post a link or point me in the right direction. Thanks for any help.
1993 mustang lx 2.3
havnt ran yet
the egr doesnt matter you can completely get rid of that and the car actually runs better im not sure the 84's were maf
84 Turbo GT
I pulled the egr valve electrical connector off and it didn't change. I think it the idle control valve. It has electrical tape around it for some reason.
84 Turbo GT
Update: I replaced the IAC valve and it didn't help. I pulled the mass air flow meter off and their was oil in the intake, So my turbo's seals are gone. The mass air flow meter was covered in oil. I cleaned the mass air flow meter and reinstalled it. It helped stop the sputtering but the car idled high. I need to get my turbo rebuilt. Does anyone know of anybody that is good at rebuilding a turbo or a company that is not to expensive, or where I can get a cheap turbo? I believe the MAF meter getting covered in oil is the problem. Hopefully.
84 Turbo GT
I found out today that my turbo is ok. I still don't understand what is making it idle bad and hessitate.
My 2000 mustang had the same problem.
I aslo changed the spark plugs on mine and it did it.. but what I didn't know is the spark plug wires need to go on the correct plug, if any are mixed this will cause the engine to have all sorts of weird idling, but then again it also caused problems drivving too |
1993 mustang lx 2.3
havnt ran yet
the oil in the intake is just a simple case of blow by my car has it alot of old cars do. ^ newb lol sorry bro but you walked right into it. did you check the coil also its a no brainer but could be a nasty air filter or you got water in your injection system some how. another no brainer but did you gap your plugs never heard of it causing wierd idle but i would just double check everything before you go dumping money but thats just me i dont have alot of it laying around lol.
check the gasket seal at the TPS. Mine had the same issue.
#9 | |
1988 Mustang LX 2.3T
What year motor are you running?
84 Turbo GT
Its an 84 motor.
![]() MIlitary Crew
E-4 |
Threads Similar to: Erratic Idle
| Aftermarket TB/Plenum hanging idle/low idle issues! | Novanutcase | 99-04 | 12 | August 13th, 2008 11:24 AM |
| erratic idle still.... | Toph6888 | V6 Mustangs | 8 | March 30th, 2008 09:29 PM |
| Erratic gauges -'87 GT | nukeworker | 5.0 Mustangs | 8 | July 22nd, 2007 11:15 AM |
| Erratic RPM in Idle | mechwife | General Tech | 7 | April 9th, 2007 01:10 AM |
| Idle Problems Code 1506, Idle Overspeed Error | jagstang96 | 96-98 | 3 | August 29th, 2006 04:11 AM |
