Turbonetics boost controller problems
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old May 23rd, 2009, 10:21 PM   #1
Turbo RANGER's Avatar
1990 Ranger Custom
11.60@116.19
Turbo RANGER is on a distinguished road
Ok, here's the deal: I bought a 0-50 psi boost controller that mounts inside. It's a single stage mechanical. Ok, the schematic says to run boost through a tee to the boost controller and the pressure side of the waste gate actuator, and then run aline from the outlet of the controller to the vaccum side of the actuator. I did all that, but it acts like it has no boost control at all. The turbo (a T3/T4 hybrid with a garrett internal wastegate and a turbonetics actuator) spools as far as it can or as I let it. I need all the help i can get, so please help me.
Superchargers are where it's at Verne
Old May 25th, 2009, 01:01 PM   #2
1988 Mustang LX 2.3T
akatagyourit is on a distinguished road
Ok to make this easier for you I drew a diagram. Ok heres how to set it up you need a tee in the line between the compressor side of the turbo and waste gate. The extra line goes from the tee directly to the inlet of the boost controller. One side lets boost in the other goes out. If the boost controller isn't working i'd ideally say something might be backwards. The tee for my boost controller has a check valve in it and only lets air go through one way to not allow unmetered air in. Hope this help.
Originally Posted by Hourofpain
If i put flowmasters on my lawn mower will it sould like a gt?
Threads Similar to: Turbonetics boost controller problems
Boost Controller???? turismo374 2005 - 2010 V6 23 September 26th, 2008 10:47 PM
Boost Controller? shortskirtsnturbos 99-04 0 August 1st, 2008 05:13 PM
Boost Controller shadowgames81 2.3 Mustangs 6 May 22nd, 2008 08:58 AM
boost controller dark-samurai2 V6 Mustangs 57 September 2nd, 2007 01:26 AM
boost controller jeremy 99-04 6 March 21st, 2007 07:17 PM
