3:55's with a 2.3 yay or nay
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old August 2nd, 2009, 06:46 PM   #1
86gter's Avatar
86gter is on a distinguished road
hi, i picked up n 89lx 2.3 and was not sure of the stock rear gear ratio in these.
i have a 3:55 rear sitting here and wondered if i should put it in? it also is a 5 speed car.
also i pulled the motor to paint engine compartment and have the head redone due to loud ticking.
i was told that these motors hold up rather well in the mileage department, i have 160,000 miles on it, should i rebuild the bottom half or just buy a spare motor for 50 bucks if this one blows.
Old August 3rd, 2009, 07:10 PM   #2
GT347SC's Avatar
89 GT, 92 LX
GT347SC is on a distinguished road
My 92 2.3 5 speed had a 3.45 rear from the factory and im pretty sure the 93 i just got has the same.
Old August 3rd, 2009, 08:21 PM   #3
86gter's Avatar
thanks for info, how can i find out what mine came with
Old August 3rd, 2009, 11:33 PM   #4
hockey's Avatar
1990 LX 2.3 Mustang
under construction
hockey is on a distinguished road
I have a 1990 auto, 4 cyl and mine has 3.73 gears. there is a tag on the rear end cover
usually at the top right side has a bunch of numbers on it it should say 7.3 or 8.8 others numbers then have the gear ratio on it .
If you rebuild the head and put it on the old block with old rings ,you are gonna blow the rings out , as redoing the head (valve job) will raise cylinder presure and the old rings will fail. what the guy did before i bought mine (it needs a rebuild)cause it to use alot of oil. hope this helps
Old August 9th, 2009, 01:50 AM   #5
notched306 is on a distinguished road
Send a message via AIM to notched306
the numbers on the tag a 3 then a letter then two other numbers,it will be on the bottom of the tag starting from the left.
my car runs on corn bitches
Joey
Old August 9th, 2009, 11:32 AM   #6
86gter's Avatar
cool thanks
Threads Similar to: 3:55's with a 2.3 yay or nay
Hood...yay or nay? coolhandluke Visual 48 August 9th, 2009 08:42 PM
MSD Knock Off . . . Yay or Nay lazy_stang 5.0 Mustangs 30 March 21st, 2009 07:59 AM
ricey yay or nay? tsp_2177 The Clubhouse 21 March 30th, 2008 10:57 PM
turbo idea...yay or nay 94pacecarSVT General Tech 24 March 12th, 2007 01:31 PM
powdercoating rims yay or nay??? GotBoost232 V6 Mustangs 20 January 18th, 2007 06:55 PM
