Discussing 5.0 Swap in the 2.3 Mustangs Forum. Would I need to change the suspension to accomodate a 5.0? What else should ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
5.0 Swap
Would I need to change the suspension to accomodate a 5.0? What else should I change?
God gave me a penis and a brain, but not enough blood to run them at the same time. |
1998 SVT Cobra
Need to? No.
Should you? Abso-f*%#ing-lutely. You should makes sure everything is 5.0 spec or better, suspension, transmission, rear-end, the works. Use the search function/google, and you'll see what the exact differences were betwen 2.3 and 5.0 cars.
*The Sacred Chao says "MU"* Real racers turn corners... both ways... on the same track. MM Corner Carvers Crew, member #2 |
1990 Mustang LX Turbo
9.71@141.6 mph
the 2.3 mustang and the 5.0 suspension were the same the only thing you would need to change is the rear axle from the 7.5 to an 8.8 posi rear
1998 SVT Cobra
That's not true. Beyond the rear end, spring rates are different, the power steering rack is different, the routing of the fuel and brake lines is different, the crossmember is different, and most importantly, the front brakes on a GT are larger - to big to fit behind stock 4-banger rims. Maybe not all technically suspension, but important differences nonetheless.
There's also at least 4 different specs of T-5 that I can think of, of which the 2.3L Mustang and 5.0 Mustangs are on opposite ends of the scale. If you think you can just bolt up a 5.0 to a 2.3-spec T-5 and go, well, more power to you. Just have a spare ready for when it goes.
1998 SVT Cobra
Sorry, I just re-read the above... when I said the crossmember was different, I meant the transmission crossmember. Realized it may not have been clear
9.71@141.6 mph
oh yeah i forgot, no but most 2.3 mustangs have the double hump cross member for the t-5's cuz my hatch was an ex-4 cyl. car and the tranny fit in it fine
Thanks guys, in case you cant tell this is my first time dealing with fords, I was raised around chevy.
9.71@141.6 mph
ohhh noo, good thing you went with Ford, your car will take care of you if drive a ford but not chevy
Threads Similar to: 5.0 Swap
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 07:48 PM |
| 3.8 swap to 5.0 | goldhorse | V6 Mustangs | 1 | August 10th, 2007 01:57 AM |
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 32 | April 8th, 2007 08:15 PM |
| PI Head Swap and Transmission Swap | jEEd | 96-98 | 6 | January 6th, 2007 03:37 AM |
| 351 Swap | Cskit1500 | 5.0 Mustangs | 6 | November 16th, 2006 08:40 PM |
