Discussing 1990 Mustang probs in the 2.3 Mustangs Forum. I'm having some problems with my mustang, it's hesitating , and has a really ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1990 Mustang probs
I'm having some problems with my mustang, it's hesitating , and has a really bad lack of power when axcellerating kinda sounds like a chugging noise. I have replaced the spark plugs and that did seems to work but only for a short while a few months best any ideas? I'm really hoping this is something simple as I don't have much money thanks
JD |
1998 SVT Cobra
Am I correct in that you're saying that replacing your plugs works for a few months, then the problem returns, and replacing the plugs again gets rid of the problem for a few more months?
If that's the case, what do the plugs look like when you take them out?
*The Sacred Chao says "MU"* Real racers turn corners... both ways... on the same track. MM Corner Carvers Crew, member #2 |
I got this Mustang in 2002 I have replaced the spark plug once since this problem started occuring last summer as I said it seemed to help but the problem returned the old spark plugs I pulled out were pretty blackened on the engine side of the plug I'm not sure if replacing the plugs again will help.
JD BTW thanks for any and all help |
Oh I also forgot to say that it does it after I have been driving it for about 15 min or so and keeps doing after the engine has come up to normal operating temp. The engine also idles at about 800 rpm is this too low? I'm thinking and hoping it justs need a tune up. I may head to auto zone and get new spark plug wires and a new battery
JD
I just drove it and when I step on the gas the ride becomes very jerky like it's not getting enough fuel or something isn't engaging right. maybe the clutch is going bad could be a number of things.
JD |
1998 SVT Cobra
Well, blacked plugs generally means it's burning oil. If that's the case, then that would explain the lack of power (oil isn't gonna give you the power gas would), Or it's running really rich, something else that'd foul the plugs.
Plugs and wires aren't going to solve your problem. For some reason, your engine is either sucking oil, or running really rich on acceleration. I also don't think it's a clutch problem at all. Worst case, I think your rings might be shot. But that's worst case. I'd check your fuel system/delivery stuff. Go through your dirty hands book and check things like your thottle position sensor and make sure that's all working right. Timing would be another easy thing to check. Make damn sure that everything is running to spec before you start buying parts.
Thanks for the help I have an appointment to take it in to a shop tomarrow.
i'm gonna have them do a tune up on it and an oil change and maybe fix the a/c and fix a few other things JD |
Hi all i got my Stang back from the shop the problem just turned out to bad a bad spark plug wire she runs great now. I was getting gas and someone offered me 1500 for the car. I don't think i want to sell it though i think it has too much potential. I'm not sure what she blue books at, but what do you all think?
Thanks JD :wink |
Threads Similar to: 1990 Mustang probs
| 1990 Mustang GTR $69k | TurboLX | The Clubhouse | 25 | October 21st, 2007 12:22 AM |
| 1990 mustang | 5mustang0 | For Sale | 14 | August 24th, 2007 01:15 PM |
| New Mustang Owner, Need some help with a few probs. | Redrider | 94-95 | 1 | October 17th, 2006 04:41 PM |
| 1990 Mustang Convertible Help | TROYFREW | 5.0 Mustangs | 2 | July 25th, 2006 04:43 PM |
| WTB: 1990 thru 1993 mustang | NXZ | Want to Buy | 4 | April 3rd, 2006 04:33 PM |
