Having fuel problems
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old June 24th, 2010, 09:02 PM   #1
mjacobs321 is on a distinguished road
Arrow
Been having some weird stall outs when the car is idling. when im driving it will bogg down badly and it will sputter then back to normal. im almost positive its a fuel problem. just lookin for some advice before i start replacing things.
Old June 25th, 2010, 01:15 AM   #2
OHC230's Avatar
Supercharged 89'/ 85' SVO
11.945 @ 119.6
OHC230 is on a distinguished road
Have you checked the fuel pressure?
What do the spark plugs look like?
Has the car had a recent tune up?
Can you hear a hissing noise coming from the engine, while its running?
Supercharged 2.7L
398 HP
501 ft lb !!
Old June 25th, 2010, 08:13 PM   #3
probably needs a good tune up
no hissing unless you mean the fuel pump which u can hear running
im thinkin its in need of a tune up and maybe a fuel filter just not sure
Old June 27th, 2010, 10:18 AM   #4
OHC230's Avatar
11.945 @ 119.6
I would start with the tune-up parts, since it sounds like you were going to do that anyway. I would definitely change the plug wires as well as the plugs. The color of the plugs can tell a story here. If they are black in color, that could indicate a rich running condition or possibly oil fouling. If they are light tan in color, that could indicate a lean condition.
Supercharged 2.7L
398 HP
501 ft lb !!
Old June 28th, 2010, 06:36 PM   #5
the plugs where white
i changed the plugs, the wires, cap n rotor, fuel filter and air filter. running better but it will still stall out and sputter.
running out of ideas i can try cleanin the fuel injectors just no sure what to use
Old June 30th, 2010, 06:34 PM   #6
still having the problems..... any ideas?
Old June 30th, 2010, 10:28 PM   #7
OHC230's Avatar
11.945 @ 119.6
If your plugs are white,it could indicate a lean condition. Check your fuel pressure next. It should be around 45 LBS. Dirty injectors are less likely.
Supercharged 2.7L
398 HP
501 ft lb !!
Old July 10th, 2010, 04:26 PM   #8
i still cant figure this thing out
could it be the fuel pressure regulator?
Old July 10th, 2010, 10:39 PM   #9
OHC230's Avatar
11.945 @ 119.6
Yes, it could be the fuel pressure regulator, or the O2 sensor or the coolant temp sensor, or a bad fuel pump, or a couple of other things.
I need a little more info, in order to help you.
Have you checked the fuel pressure? how many lbs?
Does it have a miss at idle?
Try starting the engine, let it warm up and while it is running, pull one fuel injector plug from an injector at a time and see if the idle becomes more rough or stays the same. This can tell you if you have a dead cylinder or a bad injector.
BTW Have you checked the fuel pressure?
Doing this, can help solve some of this mystery.
Supercharged 2.7L
398 HP
501 ft lb !!
Threads Similar to: Having fuel problems
Fuel gauge problems Red83GT 5.0 Mustangs 1 June 12th, 2010 08:43 PM
still fuel problems viperlocc 5.0 Mustangs 0 April 19th, 2009 10:38 AM
Fuel problems....Any help? Casper98GT 5.0 Mustangs 5 April 21st, 2008 12:23 AM
Fuel Problems 1fstcobra 99-04 14 December 10th, 2007 10:43 PM
HUGE PROBLEMS....IDLE, AIR/FUEL/FUEL PRESSURETPS HOW TO SET? 1slowhatch 5.0 Mustangs 0 April 21st, 2007 06:48 PM
