236 Whp With N/a And Esslinger Head - Page 3
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
LinkBack (1) Thread Tools
Old November 8th, 2010, 11:24 PM   #41
OHC230's Avatar
Supercharged 89'/ 85' SVO
11.945 @ 119.6
OHC230 is on a distinguished road
Brian, your English is fine. Welcome to the Forums.
You might want to read through these forums first. There is a lot of good information presented here from a lot of different people.
I think the best way to take on your Mustang project, would be to work on one area at a time.
There are many areas you can improve upon, without spending a lot of money.
I am working on a head porting tutorial for the 2.3 engine right now, for people who like to do some of their own work.
There are many posts on these forums about weight reduction.
Exhaust systems.
Camshafts.
Exhaust headers.
Gears.
Engine Tuning.
Intake systems.
Pick one of these topics that you might be interested in doing first and the rest of us can post our opinions.
Supercharged 2.7L
398 HP
501 ft lb !!
Old November 8th, 2010, 11:59 PM   #42
1991 mustang lx
BrianF is on a distinguished road
thanks for the answer ohc230 =), i had reached information in all the web about the 2.3 modifications, i´ll check all the posts on this forum to see what i can find.
I have to say that i got shocked when i saw that your stang have over 200hp, congratulations for that, you have my dream car =D
Old November 9th, 2010, 11:03 PM   #43
OHC230's Avatar
11.945 @ 119.6
Brian, we can get some performance out of your Mustang as well....and yes this car is fun!
I think that most of us on these forums are lacking in either time or money, usually both. We typically take on small projects for our cars and improve them one piece at a time. That is the way I built my car. I wanted to keep it street legal in California, “at least in spirit” so I spent money on things that most people would not have: like expensive high flow catalytic converters.
The exhaust system was one of the first things I modified on my car. I used 3” exhaust piping that gradually tapers down to 2.5” I chose an exhaust header which was originally made for a racing Pinto application, because I knew that the exhaust system would eventually have to support the other modifications that I was planning.
I almost always recommend starting with a good exhaust system, if you are serious about making real power with your engine.
The initial HP gains from the exhaust modifications are only 8-10 HP, but the potential to make more power with other additions in unleashed.
Supercharged 2.7L
398 HP
501 ft lb !!
Old December 28th, 2010, 05:43 PM   #44
2003 Mustang GT
motormenace is on a distinguished road
Question
OHC230, Where you using the stock 35 pound (brown tops) injectors with the stock 89 computer? I'm wondering this due to the 35's being low impedance and the NA computers being high impedance.....
Also, very nice numbers!!!!
Old December 28th, 2010, 06:35 PM   #45
OHC230's Avatar
11.945 @ 119.6
Yes I have installed low impedance injectors with high impedance drivers(and visa versa), both with and without resistor packs and I have yet to burn up an old EEC computer but I’ve fried a couple of OBD 1 ECU’s, due to my stubbornness and stupidity. The PK1 ECU in my Mustang is a tough little thing and has survived a lot of abuse from its owner. I think the drivers in the EEC’s were probably overbuilt. I have been told that the trick to making these reliable has to do with temperature (around 150 C is usually the max) which obviously affects reliability and because you mentioned it, thanks BTW, I will issue this disclaimer and retract any other statements issued prior to:
"WARNING" Don’t’ use low impedance injectors with high impedance drivers or visa versa, your ECU will burst into flames.
There, I feel better now. Incidentally, I am now using RC Engineering 42# injectors.
Supercharged 2.7L
398 HP
501 ft lb !!
Old December 28th, 2010, 07:50 PM   #46
free2.3's Avatar
FK UR HONDA
free2.3 is on a distinguished road
hey ive done that. i burnt up my ecu on my 84 rx7 gsl-se(first year for a 13b in rx7) when i switched to 91 lightwieght high compression rotors and a 51mm itb and accidentally ordered low impedance injectors and ran the car to 8500rpm and it just died then my carpet cought on fire haha
Nitrous is neat.... Fuel injection is sweet... but at the end of the day i'd rather be blown
91 Mustang hatch(AT)
91 Mustang hatch 2.3T
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2-3-mustangs/174532-236-whp-n-esslinger-head.html
Esslinger Ford 2 3 Performance Parts Alumiun Head This thread Refback September 25th, 2010 12:32 PM
Threads Similar to: 236 Whp With N/a And Esslinger Head
esslinger? stangfreak88 2.3 Mustangs 5 September 22nd, 2010 02:09 AM
426 whp in n/a 2v? Smoothgrandmama The Clubhouse 9 April 5th, 2009 11:35 PM
300 whp n/a? wishIhada5.0 99-04 22 August 16th, 2008 08:15 AM
236 mph Classic mustang Horseshoeing Classic Mustangs 12 September 1st, 2006 01:52 PM
