Where to start on adding AC to Non-AC 2.3l?
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old August 21st, 2010, 04:15 PM   #1
SRT LOL is on a distinguished road
Bought an 89 Notch with no ac and its killing me in this AZ heat. The firewall has a rubber grommet covering the area where the high low lines came out of the evaporator.
My question is.. is the HVAC control module different? Is the HVAC box different? Is the radiator support different to support the condenser?
Doing the work is no problem, I just need some experienced input
Thanks.
Old August 21st, 2010, 08:32 PM   #2
OneLoudMustang88 is on a distinguished road
If you buy all the factory parts from a donnor car of the same year as your car, it should all bolt right in , if your car does not have all of the wiring already in it, you will need that too
But man that is alot of work
I would sell the car and buy one with the A/C already in it.......
Old August 22nd, 2010, 12:58 AM   #3
tom_vilsack's Avatar
1988 mustang 2.3L
tom_vilsack is on a distinguished road
your in az...buy a vert ;-)
Old August 22nd, 2010, 12:39 PM   #4
Av8tor is on a distinguished road
Ya there is a lot of different stuff between the cars, I'd sell it and buy one with ac. Otherwise your taking the entire dash off to swap heater boxes, going through wiring, its just a big headache.
Old August 23rd, 2010, 08:02 PM   #5
That's where all the fun is.. I will be the one guy to go to for all the info on adding ac to non ac stangs. I figured that ill just get the box that will for damn sure fit. I found the harness under the hood for the high side sensor. The high low lines come from the firewall and on my non ac car its got a rubber gromet there. It should all plug and play. I'll probably just need a toggle switch to control a relay for the compressor clutch and a feed to the pcm for compressor command after the LSx swap.
I think i've got this down! Feel free to chime in with your ideas.
Mario
Old August 23rd, 2010, 08:03 PM   #6
"the box" being the hvac box that contains the heater, evaporator, doors, etc. and ill just replace all the underhood shit with new stuff to ensure free and clear lines, moisture bag, orifice tube, etc.
Threads Similar to: Where to start on adding AC to Non-AC 2.3l?
Rolling start compared to standing start PhillyGT 5.0 Mustangs 23 January 25th, 2012 10:49 PM
96 GT, Adding more HP/TQ? Maluther 96-98 15 April 27th, 2010 09:25 PM
Bought and 09 V6. How long till you start adding mods to it? jgibo1 2005 - 2010 V6 25 February 16th, 2009 03:34 PM
Decided On Keepin My Baby! Lets Start Adding Power!! 06BeastGT 2005 - 2010 28 January 23rd, 2009 12:18 AM
HELP WITH ADDING HP!! BOSS490 V6 Mustangs 9 June 17th, 2007 01:39 AM
