Discussing so can u put a turbo.... in the 2.3 Mustangs Forum. what kind of power u makin?... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 |
#22 |
1990 Mustang LX Turbo
8.67@165.91 mph
Hopefully around 500, i havent put it on the Dyno yet and theres still a couple thing im doin with the motor still
Wiring Diagrams, TSB's, OBD Service Codes and Engine Diagrams Available. PM For Info Myspace Small Block Posse |
#23 |
wut kinda mods u got on it¿
#24 |
8.67@165.91 mph
My mods are a built 2.3 bored 20" with a small stroke bringing it to a 2.5 with a Stinger header and a Holset HX35 with a 3" down pipe, custom built log style one piece intake, a ported and polished head with a ranger roller cam, 62lb injectors with a turbo "JOE" fuel rail, a custom intercooler (NOT INSTALLED YET) Megasquirt stand alone and there maybe a couple of more but i dont know what they are
#25 |
u kno anything about the t3/t4 turbo? i was lookin into those since it jus bolts right up to the engine and doesnt cost much to do it
and 62 lb injectors?!?!? holy shimoly! i thought 40 was overkill but damn and wut kind of gains did u get from the ranger cam and how much u get it for? and i read somewhere that turbo engines dont really like bein stroked cuz of the compression ratio or w/e and havin more room for the air inside to expand and what not. u make more power wit the stroker than normal displacement. cuz i kno u can get a long rod kit and keep the same displacement but wit lighter pistons and longer rods |
#26 |
8.67@165.91 mph
well yes and no, if your going with a huge stroke, then its a problem, but a smaller stroke is nothing, actually Rangers are 2.5's, as for the ranger cam, its a roller cam so it frees up power due to the fact that it takes a load off the engine, it makes it easier to turn, and it gives you about a 15hp gain and yes i do know alot about the Garrett T series
#27 |
when i said u kno anything about... i wasnt askin if u knew. i was askin u to tell me wut u knew lol
so u can take the 2.5 ranger cam and put it on a turbo 2.3 w/ no other mods? |
#28 |
8.67@165.91 mph
same motor just with a stroke, also since it would be too much to write about the T3/T4, just look at this link below
http://www.well.com/~mosk/biggerturbo.htm
#29 |
so if u jus bolted the t3/t4 on u wud hav to get new fuel pumps?
#30 |
8.67@165.91 mph
well first off, is the engine a turbo block?
#31 |
yea its a turbo 2.3L from a t-bird
#32 |
8.67@165.91 mph
ohh ok sweet, i would bolt the T3/T4 up to it and use 42lb injectors with a 255lph fuel pump and a FPR, are you using the EEC from the Tbird?
#33 |
i didnt swap it yet. its jus sittin there
and how much wud all htis cost? i wanna do it all at once cuz im gonna get new gears for the tranny too |
#34 |
8.67@165.91 mph
it shouldnt cost alot, if you have a complete engine and EBAY
#35 |
ebay is ur friend in the world of poverty lol
i wonder wut kind of power gains i wud get from a t3/t4 wit the 42lb injectors and the fuel pump and fpr |
#36 |
also, wud u need some kind of aftermarket computer or anything to run properly?
#37 |
8.67@165.91 mph
you can use the stock EEC but its good for only 300hp, that combo should get you about 350-400 and Megasquirt you would need to run
#38 |
ohh u do it urself.. i assume u did this? is it ez, hard, pro needed?
#39 | |
8.67@165.91 mph
#40 |
does that gotta be custom ordered or something?
Threads Similar to: so can u put a turbo....
| Turbo is done, got a question for you turbo guru's | Regency 2007 | 2005+ | 33 | June 26th, 2007 08:46 AM |
| Supercharger, Twin Turbo, and Single Turbo | justinsstang | Poweradders | 24 | March 7th, 2007 09:07 PM |
| Mellon's Twin Turbo Stealth vs Wills99z's Single Turbo z28 | Mellon | Videos | 10 | December 30th, 2006 10:05 AM |
| Turbo, Twin Turbo, Procharger, or Kennebell? | black94gt | 5.0 Mustangs | 19 | October 7th, 2006 10:41 AM |
| Super Charger vs Turbo/Twin Turbo: Pros and Cons of each | FireryDriver | 2005+ | 9 | September 17th, 2006 04:15 PM |
