How can you test for IAC failure ?
It seems to be a new IAC valve for the 2.3 is about $100. I will buy it if I have to but I want to be sure its failed and not just dirty.
Is there a way I can test this ? Either way Im going to at least remove it and clean it out and give it another go before I open up the wallet for a purchase. Please Advise Thanks ,
1990 5.0 LX - Manual (for play) 1991 2.3L LX - Auto (for street) 1989 2.3Turbo - In the Works 1988 Thunderbird Turbo Coupe 2.3Turbo - (K&N , Gillis Boost Valve, Auto to T5 SWAP ) ![]() Yeah I'm a mustang Newbie - wanna fight about it ? |
its fine mostly during normal driving but when I let it idle like at a stop light it sputters and shuts off.
It does this in park as well. I filled up the tank w premium and ran it for a bit to see if it was some messed up gas but no go its still acting up. As long as I give it gas it's fine but when I come off it the car wont stay up. it does this when the RPM's drop under 1k. but if I keep it over all is well
1988 Mustang LX Turbo
yep thats it then, you can find a cheaper IAC from ebay or a donor, there all pretty much universal, the 5.0 ones should fit to
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
try cleaning it out first with some carb cleaner also I would try cleaning and re setting the TPS also.
Thanks
I cleaned it out and put i tback on and the issue was still the same so I was lucky enough to find another IAC for "FREE" and the car runs like a champ.
my tranny was acting up and rear was making noise so I got all that replaced as well. Total cost of everything $250.00 - I love Georgia Salvage Yards
#8 | |
Threads Similar to: How can you test for IAC failure ?
| Random Failure? | MSTGGT00 | 99-04 | 9 | September 15th, 2007 03:52 PM |
| drag day...failure | itschristorres8 | Drag | 16 | July 26th, 2007 01:04 AM |
| odometer failure | Plays With Squirrels | 96-98 | 22 | July 6th, 2007 09:41 PM |
| Failure.......*tear* | lwhitetrash88l | V6 Mustangs | 30 | April 14th, 2007 09:19 PM |
| Cam Bearing Failure | 99mustang232 | V6 Mustangs | 5 | November 2nd, 2006 02:14 AM |
