Roller cams, any drilling needed?
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old September 23rd, 2010, 10:56 AM   #1
89Bullitt's Avatar
1989 Mustang
89Bullitt is on a distinguished road
Im a 302 guy and i know that inorder to have a roller cam, your block must be drilled to accept the spiders. Is the same required for an 89 2.3 to have a roller cam? or are they all rollers (but came flat tappet from the factory like the 5.0 trucks)
600 dollars, a taillight and windshield. 4 cylinder auto, soon to be a turbo car!
Old September 23rd, 2010, 11:16 AM   #2
Av8tor is on a distinguished road
The 2.3 in a mustang doesnt work the same way as a 5.0 when it comes to the cam. Its a OHV engine vs a OHC. So in the 2.3 it would be roller followers not lifters like in a 5.0. And with a 5.0 there are ways to go roller without having to put in the spider and drill and tap it. Comp cams sells a retrofit kit which just ties the pairs of lifters together, its just not a super cheap kit.
Old September 23rd, 2010, 11:23 AM   #3
89Bullitt's Avatar
1989 Mustang
Any pics of these roller followers?
yeh like 400 bucks into lifter, no thanks lol
Old September 23rd, 2010, 10:52 PM   #4
OHC230's Avatar
Supercharged 89'/ 85' SVO
11.945 @ 119.6
OHC230 is on a distinguished road
400 bucks into lifters, no thanks lol
Ford OHC 2300 cam followers are cool little things. They can easily be procured from a wrecking yard for penny's on the dollar and they are so robust that they can be used again and again, even with different camshafts.
I you manage to grab both a roller camshaft and a set of followers from a wrecking yard, the cam can be reground for more lift. A cam grinder wont be able to do much for the lobe center lines, but an extra .050" valve lift, ground into the stock profile, can boost the engines total gas flow by a significant amount. I have tried this before and I was pleased with the results. It's a good "poor man's" way, to get into a roller cam. If you decide that you are interested in doing this, please re-post as there are a few more details about this. BTW, stock 2300 lifters/lash adjusters, typically work fine with most hydraulic cams. They also can be re-used in most cases.
Now...what were you saying about $400??????
Supercharged 2.7L
398 HP
501 ft lb !!
Old September 23rd, 2010, 10:59 PM   #5
89Bullitt's Avatar
1989 Mustang
I was talking about the linked lifters lol
I am interested in the roller cam swap but that wont happen for a while
Old September 23rd, 2010, 11:20 PM   #6
OHC230's Avatar
11.945 @ 119.6
Ahh, I see.
Supercharged 2.7L
398 HP
501 ft lb !!
Threads Similar to: Roller cams, any drilling needed?
CAMS coming soon...Power Estimate & Advice needed!!! Blown284 96-98 6 June 15th, 2010 06:41 PM
Drilling Holes in the Stang yelsir06 Visual 17 July 31st, 2007 09:12 PM
Drilling out scoop on stock 99 gt hood Jeff99gt 99-04 6 January 30th, 2007 05:45 AM
roller cams stang fanatic 5.0 Mustangs 2 August 9th, 2006 06:39 PM
