1991 Mustang LX 2.3
Octane Adjust Plug
Has anyone experimented with this little device to find out if changes in the removal or replacement of the plug with one of a different value can generate increased spark advance?
Rob 1987 Mustang 2.3 LX Convert (T5) project 2.5 N/A HP 1991 Mustang 2.3 LX Convert (A4LD) 1992 Mustang 2.3 LX Convert (A4LD) 41.52 mpg!! 1994 Capri XR2 1.6 Turbo Convert 1999 ZX2 S/R 2.0 Coupe http://zxtuner.com
Supercharged 89'/ 85' SVO
11.945 @ 119.6
Unfortunately, the octane switches used in turbo Fords are not proportional: they are either on or off. On the bright side, several companies offer dash adjustable timing controls. I use one made by MSD in my car and it was worth every penny.
![]() Supercharged 2.7L 398 HP 501 ft lb !! |
#3 | |
1991 Mustang LX 2.3
1991 Mustang LX 2.3
No resistance, so it just opens the circuit to let the ecu to make timing changes. So... does that mean removing the octane plug retards timing or advances?
If it advances, then it might be a n/a power adder. If it retards, it might be good for the NA to turbo crowd... looks like the timing light needs to come out for a little experimentation
93 Mustang LX 2.3 T-5
Any results? My timing light is screwed so i cant even try this...
93 2.3l LX U.S. 15x7 ten hole rims Calypso green Moates QH T-5 Conversion Dual 2.5" Exhaust with Thrush Welded muffler
1991 Mustang LX 2.3
not yet... my timing light crapped out so i found a nice adjustable one on ebay and got it last week. Its a fun new toy... it's a craftsman and it's inductive with breakaway cables and a timing adjustment knob for checking distributor advance and confirming cam timing.
my first use of it was to check to see if both coils on the 8 plug motor fire with the same initial timing. They do.
So then what is the point of having two sparks? I mean really, unless its igniting unburnt gasses outside of the quench area, its not doing a damned thing is it? Would it be smarter to switch to a d-port head and port the hell out of it? Since the dual plugs arent really beneficiall...
#8 | |
1991 Mustang LX 2.3
ford needed the extra spark help to meet the federal emissions warranty period (if the cars can't run clean for over 50k miles then they fail the tests)
FK UR HONDA
it also completely burns the fuel having 2 flame fronts instead of 1. because normally the quench area disrupts the flame front causing poor combustion. thats why you want to run a flat top piston with small open chambers(keep compression) witch promotes the best scavenging, swirl, and burn(it is what top fuelers run). the only down fall to that is you have to have valve reliefs in the piston and you also just created an interference motor. but fords brilliant engineers just decided to throw another plug in there(European crap alphas are famous for twin plugs hence the gay spark plug wires) instead of redesigning the head and pistons to meet emissions.
1991 Mustang LX 2.3
that and henry ford's cousin was the spark plug salesman selling the idea to management lol
AHAHA classic
Threads Similar to: Octane Adjust Plug
| Champion Spark Plug 7989 Double Platinum Plug | UNVMYGT | 2005 - 2010 | 6 | November 24th, 2011 01:50 AM |
| so i ran 87 octane with my 93 octane tune and this is what happened..... | stangman92 | 99-04 | 32 | April 9th, 2010 10:57 AM |
| Adjust trunk | Smartoss | 99-04 | 11 | March 26th, 2010 07:26 PM |
| Headlight Adjust | 06Stang | 2005 - 2010 | 10 | January 25th, 2008 01:05 PM |
| octane plug | chrisey | General Tech | 1 | April 26th, 2006 12:25 PM |
