Overruning clutch alternator pulley...
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old September 28th, 2010, 09:13 PM   #1
1991 Mustang LX 2.3
zonker is on a distinguished road
What is it you ask? Its a alternator pulley thats designed to freewheel when decelerating and engage when accelerating.
Its used typically on smaller displacement motors (like new ford focus and transit) to help control engine vibration and hp loss during gear changes.
In theory it seems like this might be of some benefit to the mustang as well, especially 5 speed models,because of the alternators ability to keep its rpms up when the motor decels to meet the next gear.
So... basically it will give back a couple ponies of alternator pull until the motor rpm meets the alternator speed.
I found a pulley that will fit the 87-93 alternator and i'm thinking of adding it.
Thoughts? Additional ideas?
Rob
1987 Mustang 2.3 LX Convert (T5) project 2.5 N/A HP
1991 Mustang 2.3 LX Convert (A4LD)
1992 Mustang 2.3 LX Convert (A4LD) 41.52 mpg!!
1994 Capri XR2 1.6 Turbo Convert
1999 ZX2 S/R 2.0 Coupe
http://zxtuner.com
Old September 28th, 2010, 11:42 PM   #2
OHC230's Avatar
Supercharged 89'/ 85' SVO
11.945 @ 119.6
OHC230 is on a distinguished road
I like the idea, except for the fact that those extra parts add mass to the pulley and there's some extra parts to break, but if you get one cheap enough, who cares, right?
Supercharged 2.7L
398 HP
501 ft lb !!
Old September 29th, 2010, 10:58 AM   #3
1991 Mustang LX 2.3
they're about 70 bucks for the pulley, and another 20 for the tool to install/remove them.
they do weigh more (the one I have here weighs 1 lb 1 oz) but thats not treeibly bad compared to the stocker
Rob
http://zxtuner.com
Old September 30th, 2010, 08:09 PM   #4
skatz420 is on a distinguished road
ya that sounds good but won't the rpms drop slower when you shift? does that pose any problems with speed shifting?
Old September 30th, 2010, 11:13 PM   #5
1991 Mustang LX 2.3
it's the other way around, the alternator will freewheel when you let off the gas to shift reducing the flywheel effect you'd get from forcing it to spin at the same speed as the crank.
Rob
http://zxtuner.com
Threads Similar to: Overruning clutch alternator pulley...
Alternator Pulley skipb88 V6 Mustangs 2 April 28th, 2010 05:41 PM
Pulley on alternator Ticket-Me-Yellow V6 Mustangs 5 June 19th, 2009 03:19 PM
alternator pulley mustangjl 99-04 2 May 25th, 2008 12:59 AM
Alternator Pulley 95blackbeauty 94-95 6 December 10th, 2007 01:35 AM
Alternator Pulley.... PLEASE HELP! msolaas1 2005 - 2010 5 June 21st, 2007 02:48 PM
