Re-Drilling Axle / Rotor Lug Pattern
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old September 29th, 2010, 11:18 PM   #1
KaLiKo Street
Street's Avatar
'92 Fox Body Coupe
Street is on a distinguished road
Is it possible to just take your four lug axles and remove the studs and re-drill the holes to make it five lug? Possible with rotors?
My Babies
92 5.0 Fox, 97 2.0 Turbo GST Eclipse, 00 2.0 Jetta, 06 GSXR 600, 98 CBR 600, 01 GSXF 600
Old September 29th, 2010, 11:24 PM   #2
OHC230's Avatar
Supercharged 89'/ 85' SVO
11.945 @ 119.6
OHC230 is on a distinguished road
Not without a fair amount of effort, most people just swap rotors and axles.
Supercharged 2.7L
398 HP
501 ft lb !!
Old September 29th, 2010, 11:28 PM   #3
KaLiKo Street
Street's Avatar
'92 Fox Body Coupe
I was thinkin more along the lines of letting a machine shop redrill them...
My Babies
Old September 29th, 2010, 11:34 PM   #4
89Bullitt's Avatar
1989 Mustang
89Bullitt is on a distinguished road
Axles? yes you can.
600 dollars, a taillight and windshield. 4 cylinder auto, soon to be a turbo car!
Old October 3rd, 2010, 04:08 PM   #5
TaterTodd's Avatar
1988 Mustang LX coupe
TaterTodd is on a distinguished road
If your wanting a 5 lug swap there's an easy way to accomplish this ... Salvage yard .. Have you ever heard of Steve Magnante? I've had this article or rather a copy of this article for quite some time. I wish I could find it online to better explain this with pictures but I'm going to write it out for ya.
And I quote "It's a little known fact that you can mix and match goodies in the self serve wrecking yard before you pay and get a better deal. The flat-rate price structure makes this possible, and in my extensive boneyard travels, the yard operators don't really care as long as they get the dollar amountposted on the price board and you don't wreck stuff in the process. Here's how to upgrade any 86-93 Fox Mustang 8.8 Traction-loc axle to five lugs in the field before you pay. The trick also applies to non-limited slip 8.8s as well as all Fox-body 7.5 axles.
1 Making sure to contain all fluids, pop the cover and pull the "death-clip", cross-shaft, C-clips, and brake drums. The stock four-lug axleshafts will pull right out. Take care not to hurt the axle seals.
2 The A-R-B passenger-side axleshaft is 26.25 inches long, too short to fit the Mustang housing. This is why you'll need two of the 29.16-inch driver-side axleshafts. When it comes to brakes, many A-R-B light trucks came with 10-inch brake assemblies that bolt directly to the ends of the Mustang housing.
A-R-B meaning '83-'95 Aerostar, Ranger, Bronco II
88' coupe 5spd ...
Threads Similar to: Re-Drilling Axle / Rotor Lug Pattern
Lug pattern mustangmallory 2005 - 2010 12 January 21st, 2010 02:05 PM
Should I convert from a 4 lug pattern to a 5 thecryptkeeper 5.0 Mustangs 35 July 3rd, 2008 03:51 AM
Lug Pattern for 89 LX 89LXProject General Tech 2 November 12th, 2007 03:40 AM
Drilling Holes in the Stang yelsir06 Visual 17 July 31st, 2007 09:12 PM
Drilling out scoop on stock 99 gt hood Jeff99gt 99-04 6 January 30th, 2007 05:45 AM
