1965 Mustang convertible
Just got a 1989 25th Anniversary 2.3L Vert, has knock
It's white on the outside, red on the inside, with the red stripes under the doors. It's realy dirty on the inside. It seems to drive OK considering it's been sitting for about 4+ years. I will check if the top works tomorrow. But the major systems seem to work: starts, drives, stops ...
Here's my question: how do I know if the knocking sound from the engine is rod knock or spark knock. It seems to vary by? |
#2 | |
1991 Mustang LX 2.3
as for the "knock"... if it does it while idling, it's surely not spark knock. there are other things that cause knock too, like excessive valve clearance from a collapsed valve lifter(s), or piston slap. if the knock seems louder around the oil pan than the valve cover, then it could be rod knock. if it's louder around the valve cover, then it's head related and probably a collapsed valve lifer which in coparison is a small problem. to isolate if it's rod knock or piston slap... while idling, pull the spark plug or fuel injector wire and see if the knock goes away. try that on every cylinder, one at a time. if you find a cylinder that makes the knock goes away, then there's a good chance its rod knock or piston slap. That means time to rebuild the bottom end or find another used motor
Rob 1987 Mustang 2.3 LX Convert (T5) project 2.5 N/A HP 1991 Mustang 2.3 LX Convert (A4LD) 1992 Mustang 2.3 LX Convert (A4LD) 41.52 mpg!! 1994 Capri XR2 1.6 Turbo Convert 1999 ZX2 S/R 2.0 Coupe http://zxtuner.com
Supercharged 89'/ 85' SVO
11.945 @ 119.6
Well, first off +1 on what Zonker said. All of it, very good info. If I may, allow me to chime in. This is a common problem with a lot of 2.3L Fords and and a lot of cars in general. There are a lot of cars in the wrecking yards because of this exact problem, but here's the catch, many of those don't have bad rod bearings or damaged piston skirts. As a career mechanic, I have serviced hundreds of vehicles and many with a supposed rod/ piston knock. Out of those I've repaired, only a very small percentage actually had failed bearings or pistons. By far the most common cause of engine knock comes from carbon build-up inside the engine. Long before I would tear into the engine, I would do a thorough de-carbonizing of the engine. "Sea Foam" is good product for this and is inexpensive to use. It can be siphoned through the intake manifold, through the PCV hose. The flow of fluid can be regulated by pinching the hose with a pair of vise grips. An engine speed of 2,000-2500 RPM works well for this.
![]() Supercharged 2.7L 398 HP 501 ft lb !! |
#4 | |
#5 | |
1988 mustang 2.3L
+1 on seafoam...what i did on my 93 vert
-used seafoam (used 1/3 can threw vacuum line)...pour slowly and keep engine revs about 2000-2500 (i did threw brake booster vacuum line,and put a small funnel into line and poured slowly...1/3 can in about 4-5 min) turn off engine,let sit for a good 10 min,then drive it for 15-20 min like you "stole it"..be prepared to white smoke out your neighbourhood. -then cleaned IAC (i found using seafoam and q-tip worked well)..i took off and put into a cup of seafoam right up to just below plastic part...let sit for 5 min...and gently cleaned inside both ports outside ect...replace and once again drive around for a few min...cleaning iac really settled my idle down (before was having surges) -you might also consider cleaning throttle body...once again i used seafoam and a clean rag -with whatever seafoam you have left...pour into full tank of gas. least for me...above steps made a hugh difference...car ran poorly beforehand...but now runs like a top.... good luck |
1988 Mustang LX coupe
What's this seafoam? I've never heard of it ....
88' coupe 5spd ...
1991 Mustang LX 2.3
seafoam is a solvent used much in the same way you'd use gumout or chemtool
it's been around for a long time, but recently has won favor as being the bees knees for gunk removal in your motor.
BTW, Here's the car I got before I washed it:
Well, it looks like the hammer lick knock sound does not go away by removing individual spark plug wires.
The sound seems loud on both the top and bottom of the back of the motor. I guess I could take the valve cover off and take a look to see if anything "sticks out" :0( My guess is that I will be looking for a new motor or at least a new head. |
#11 | |
1991 Mustang LX 2.3
Ok, So I did the sea foam and there was plenty of white smoke. I still hear the hammer sound at the back of the engine. I have not replaced the spark plugs or wires yet.
The hammer sound almost goes away around 2500 RPM. It may be a bit louder on top. How can I tell if it's a bad valve lifter. Do I just replace them all? |
1991 Mustang LX 2.3
It's probably a collapsed lifter... thats a common occurrence relative to a rod or piston knock.
Try throwing a can of marvel mystery oil in the crankcase and drive the car lightly for about 20 miles or so. Then drain and refill with some fresh oil and filter. That might do it. If not, then just replace all 8 lifters since the others are probably just as close to gumming up as the one that did.
It was a long time ago. Just to follow up on the thread. It was not the lifters. I never did figured it out. I sold the car.
1988 Mustang vert 2.3L
i also found using the berryman b-12 chemtool on cleaning your IAC works very well... i bought some from work the other night and had to clean out my IAC because of idling issues..im gunna have to try the seafoam on my car next...
1988 mustang lx
never ran down a track
seafoam is fun to use lol especially in town
Threads Similar to: Just got a 1989 25th Anniversary 2.3L Vert, has knock
| june 25th san marcos | UnixHH | Southwest | 0 | June 25th, 2010 10:43 PM |
| April 25th Show in PA | YeloPony | Northeast | 35 | April 22nd, 2010 11:39 PM |
| March 25th Bradenton Motorspeedway | Mustang Boy | Southeast | 0 | March 8th, 2010 11:39 PM |
| April 25th track day? | Cricket | Southeast | 28 | April 9th, 2008 07:53 PM |
