Underdrive Pulley - Junkyard Style! - Page 3
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
LinkBack (2) Thread Tools
Old February 6th, 2011, 12:39 PM   #41
1995 SVT Cobra
Cobraman1024 is on a distinguished road
Originally Posted by zonker View Post
sounds like measuring time with your old belt. take a cut belt and lay it in all the pulleysand mark where it overlaps, then measure the length and subtract 1"- 1.5" and try out a belt with that size.
Or I could just drive the car up to Advance Auto Parts or somewhere, remove the belt and have them match it up with one on their belts rack lol......They've got a belt measurement tool too.
1995 SVT Cobra #182/4005, 275/305, 217k miles
1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles
1995 Mustang, 3.8L, 233k miles
1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles
sold: 1987 GT
MM Military Crew Member
MM+Cleavage member #21
Old February 6th, 2011, 12:48 PM   #42
1991 Mustang LX 2.3
zonker is on a distinguished road
i know your just talking about removing a belt quickly and walking it in but i prefer not to work on my car in front of the parts store.
it hurries me and i usually wind up leaving with some messed up compromise on what i actually needed to do since i am that particular parts store's bitch until my car is back on the road.
Rob
1987 Mustang 2.3 LX Convert (T5) project 2.5 N/A HP
1991 Mustang 2.3 LX Convert (A4LD)
1992 Mustang 2.3 LX Convert (A4LD) 41.52 mpg!!
1994 Capri XR2 1.6 Turbo Convert
1999 ZX2 S/R 2.0 Coupe
http://zxtuner.com
Old February 10th, 2011, 08:11 AM   #43
1995 SVT Cobra
I just to prefer to not have to change belt sizes two or three times before the right length is found. It's worse when you can't try the belt on your car until you get home only to find out that its too short or way too long.
My '95 Cobra was always the worst for finding the right length belt; I was using BBK u/d pulleys with the air pump deleted. finally I just ended up putting the factory pullies back on and then finding a belt was a little easier. Autozone and Advance don't have a problem with test-fitting belts in the parking lot. Usually only takes a few minutes anyway.
sold: 1987 GT
Old February 16th, 2011, 09:41 PM   #44
1991 Mustang LX 2.3
bumpski
Rob
http://zxtuner.com
Old February 17th, 2011, 12:48 AM   #45
mattabater's Avatar
1992 Mustang LX
mattabater is on a distinguished road
what if i plan on taking all the a/c componets out how would i set this up then?
92' 2.3n/a LX soon to be 2.3T SVO Clone
Old February 17th, 2011, 12:55 AM   #46
1991 Mustang LX 2.3
leave the a/c idler and run the belt: crank - water pump - idler.
you'll need to measure up a new shorter belt
Rob
http://zxtuner.com
Old May 7th, 2011, 02:07 PM   #47
thedriver33 is on a distinguished road
still cant find a dang ranger lower pulley to save my life.
-87 5.0 notch (slowly being built.....)
-92 5.0 Hatch (getting ready to be DD)
-93 2.3 notch (DD)
-(sold) 96 3.8 coupe
-(sold) 82 5.0 hatch
-(sold) 85 2.3 Coupe
-(sold) 91 5.0 Coupe
-(sold) 91 Hatch 5.0
Old May 8th, 2011, 12:17 PM   #48
1995 SVT Cobra
I must be missing something here.............are you referring to a setup that uses the Ranger crank pulley?
my '93 has a separate belt that runs crank/waterpump/AC. I just removed that belt when the clutch went out on my compressor.........and then I removed the compressor, compressor bracket, accumulator and condensor. The condensor was badly damaged by the previous owner of my car and needed to be replaced anyway.
sold: 1987 GT
Old May 8th, 2011, 12:17 PM   #49
Cgross609's Avatar
93 Mustang LX 2.3 T-5
Cgross609 is on a distinguished road
Why Waste your money at all? Just run it without the AC belt altogether! Thats what i did when my A/C compressor seized up.
93 2.3l LX
U.S. 15x7 ten hole rims
Calypso green
Moates QH
T-5 Conversion
Dual 2.5" Exhaust with Thrush Welded muffler
Old May 9th, 2011, 11:48 AM   #50
ranger50toy's Avatar
1988 2.3L Hatch
Ha-Ha
ranger50toy is on a distinguished road
Zonker's underrrive set-up uses the A/C belt to drive the water pump.
Old December 25th, 2011, 07:23 PM   #51
murdered96 is on a distinguished road
Will this work on a 96 ranger 2.3
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2-3-mustangs/186269-underdrive-pulley-junkyard-style.html
Underdrive...junkyard style - Ford Ranger Forum This thread Pingback March 20th, 2012 02:09 PM
1993 Mustang LX N/A 2.3L - Page 5 - MustangForums.com This thread Refback December 24th, 2010 01:15 AM
Threads Similar to: Underdrive Pulley - Junkyard Style!
Does this look like a race underdrive crank pulley & stock water pump pulley? STREETFIGHTER50 5.0 Mustangs 8 January 26th, 2010 10:47 AM
Underdrive pulley 06dkkiser 2005 - 2010 V6 10 October 28th, 2009 02:25 PM
underdrive pulley Toph6888 V6 Mustangs 34 February 29th, 2008 03:26 PM
underdrive pulley Baker02125 V6 Mustangs 23 December 25th, 2007 01:20 AM
Underdrive pulley firefly1241 5.0 Mustangs 20 December 9th, 2006 02:13 AM
