Underdrive Pulley - Junkyard Style!
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
LinkBack (2) Thread Tools
Old October 4th, 2010, 12:11 AM   2 links from elsewhere to this Post. Click to view. #1
1991 Mustang LX 2.3
zonker is on a distinguished road
2.3 Underdrive Pulley - Junkyard Style!
I've been trying to come up with a way to underdrive the accessory pulleys on my 1991 2.3.
I purchased a Esslinger UDP to fit one onto my car and found out after I removed the stock pulley that it will not work on a 91-93 dual plug 2.3.
It's a shame too, since the esslinger pulley is a beautiful piece that would have given me a 32 percent
underdrive across the board.
So... if you have a 2.3 with a distributor like the 87-90 2.3 Mustangs and 87-88 T-Bird Turbos, go with the $90 Esslinger pulley.
But, if you have no distributor like me, then here's your current best option:
Here's what I now have on my car:
1992 Ford Ranger 2.3 Double Belt Crank Pulley
1988 Ford T-Bird Turbo 2.3t Water Pump Pulley
1994 Ford Explorer 3.0 V6 Alternator pulley
537k6 Alternator Serpentine Belt
427k6 A/C Compressor Serpentine Belt
Here's how much it's has underdriven the accessories:
Alternator - 31%
Power Steering - 14%
Water Pump - 14%
Air Cond - 5%
OLD BELT ROUTING
1. Alternator, Water Pump, Power Steering, Crankshaft
2. Water Pump, A/C Compressor, Crankshaft
NEW BELT ROUTING:
1. Alternator, Water Pump, Power Steering (not on crank anymore)
ORIGINAL PULLEY SPECS - 1991 Dual Plug 2.3:
Crank - dual belt - 6.1875" and 4.9375"
W/P (p/n F1ZE-8509-AA) - dual belt - 5.3125" and 4.3125"
Alternator - 2.5625"
NEW PULLEY SPECS:
Ranger Crank Pulley - dual belt, 6.1875" and 4.6875" diameters
(IMPORTANT NOTE: you only put a belt on the 4.6875" pulley, the 6.1875" pulley is left blank)
T-Bird WP pulley (p/n E7SE-8509-AA) - dual belt, 5.875" and 4.75" diameters
Explorer Alt Pulley - 2.875"
RESULTS:
The car does rev a little easier, and there is a small seat of the pants improvement. I should even see a small mpg improvement as well since it will require less effort to turn all those pulleys.
CONCLUSION:
A worthwhile mod for the cost of 3 used junkyard pulleys and a new serpentine belt.
FUTURE PLANS:
I still hope to have Esslinger make us a water pump pulley that will further underdrive the water pump,
alternator, and ps pump by using a billet 5.875" / 5.875" dual belt pulley, but for now this is the best I can come up with.
Rob
1987 Mustang 2.3 LX Convert (T5) project 2.5 N/A HP
1991 Mustang 2.3 LX Convert (A4LD)
1992 Mustang 2.3 LX Convert (A4LD) 41.52 mpg!!
1994 Capri XR2 1.6 Turbo Convert
1999 ZX2 S/R 2.0 Coupe
http://zxtuner.com
Old October 4th, 2010, 03:56 PM   #2
TaterTodd's Avatar
1988 Mustang LX coupe
TaterTodd is on a distinguished road
wow, dude you put some thought into that ... would have liked to see some dyno pulls of the before and after ... I'm curious as to how much of a difference it makes. Good going!
88' coupe 5spd ...
Old October 4th, 2010, 06:30 PM   #3
1991 Mustang LX 2.3
thanks - it was my obsession this last week to get it figured out...
As for how much power, since its a seat of the pants feel, my butt dyno puts it in the 4-5hp range. On zetecs a 25% underdrive ratio gives 6-8hp on the dyno, and anything less than a 4-5 hp bump is not discernable to the 'ol butt.
to give you an idea of how that affects the accessory rpms, compare the following:
Stock 1991 2.3 (1000, 2500, 5000 engine rpm):
crank - 1000, 2500, 5000 rpm
water pump - 1164, 2910, 5820 rpm
power steering - 1062, 2656, 5310 rpm
alternator - 2750, 6875, 13750 rpm
Modified Pulleys
water pump - 996, 2490, 4980 rpm
power steering - 1005, 2512, 5025 rpm
alternator - 1875, 4687, 9375 rpm
One can see how hp is made by how much slower the accesories have to turn.
Also figure they'll last longer too, since they're spinning at a slower speed.
Rob
http://zxtuner.com
Old October 6th, 2010, 09:56 PM   #4
1991 Mustang LX 2.3
Did another timed run with my Android phone after the pulley change - It has given me 0.2 seconds from 0-30 mph and in the 1/8 mile.
Not bad, it's the most new hp I've gotten so far from my driveway tinkering.
Rob
http://zxtuner.com
Old October 12th, 2010, 01:04 PM   #5
thedriver33 is on a distinguished road
Not a bad upgrade.....just finished mine, im not running a/c so i left stock crank pulley, 2.3t w/p pulley, 94-98 v6 ps pulley........not doing the alt pulley cuz i plan to do a 3g upgrade for mine here in a bit.
But with that pulley upgraded and ranger header, blocked egr......and modded air box, this car is starting to move better.
-87 5.0 notch (slowly being built.....)
-92 5.0 Hatch (getting ready to be DD)
-93 2.3 notch (DD)
-(sold) 96 3.8 coupe
-(sold) 82 5.0 hatch
-(sold) 85 2.3 Coupe
-(sold) 91 5.0 Coupe
-(sold) 91 Hatch 5.0
Old October 12th, 2010, 02:48 PM   #6
1991 Mustang LX 2.3
If you don't run ac but the car still has the tensioner for the AC then you can run the ranger crank pulley and run crank-waterpump-tensioner on the outside and waterpump-powersteer-alternator-tensioner on the inside. That will give you another 5% underdrive on the w/p, alt, and PS.
Rob
http://zxtuner.com
Old October 12th, 2010, 02:54 PM   #7
...i couldnt find any 2.3 rangers in the yard......only found 2 bodys that had nothing....but i was amazed to find that turbo coupe with everything there on it....going back next week to get some more stuff off it, and see if cant get a ranger pulley.
may grab the turbo manifold, injectors, valve cover.........the turbo was beat......shaft play was huge....
-93 2.3 notch (DD)
Old October 12th, 2010, 03:58 PM   #8
1987 ford mustang
87fourbanger is on a distinguished road
What?? Sounds interesting but Dnt know what this is about. If any one has ex time to enlighten me w info on what zonker is doing to his car. Thanks
Old October 12th, 2010, 06:05 PM   #9
he used other stock pulleys from other 2.3s to make a underdrive system from our cars.....i followed his idea and included an addition pulley.....but i still need one more pulley to finish mine.
-93 2.3 notch (DD)
Old October 12th, 2010, 11:12 PM   #10
1991 Mustang LX 2.3
How much enlightenment do you need, grasshopper?
Is the whole underdrive concept a mystery?
Underdrive Pulleys = Power Pulleys (another word used for them)
It's all about making the engine work less hard to turn the accessories (water pump, air cond compressor, power steering pump, alternator). This is accomplished by changing the diameters of the pulleys in order to slow the rpms of the engine accessory(s).
Clearer?
Rob
http://zxtuner.com
Old October 12th, 2010, 11:35 PM   #11
blaten22's Avatar
89 LX
blaten22 has a spectacular aura aboutblaten22 has a spectacular aura about
Send a message via Yahoo to blaten22
May sound a bit stretched but food for thought. Wonder if you could get or makeshift an Electric water pump?.
Old October 12th, 2010, 11:56 PM   #12
1991 Mustang LX 2.3
that would be a way to reduce some of the parasitic losses as well, and they are nice in the sense that you can have a constant flow rate, but i think some of the gains you see are eaten up by additional hp load on the alternator.
also there's a long term quality issue to deal with too. Meziere for example says the pump motors are used up at 75k miles.
it might not be worth the investment imo
Rob
http://zxtuner.com
Old October 13th, 2010, 12:21 AM   #13
1987 ford mustang
So u get bigger diameter pulleys?
Old October 13th, 2010, 01:26 AM   #14
1991 Mustang LX 2.3
yes, and no...
drive pulleys need to be smaller and driven pulleys needs to be larger
Rob
http://zxtuner.com
Old October 13th, 2010, 04:20 PM   #15
1987 ford mustang
Ok.. I'm trying to get it. Drive pulleys and driven? What's the diff
Old October 13th, 2010, 04:39 PM   #16
PunkRockGearhead88's Avatar
1993 Mustang LX 2.3 Notch
PunkRockGearhead88 is on a distinguished road
Im curious, if your car is an auto, how is it charging at a red light in gear with your foot on the brake and the A/C on?
Old October 13th, 2010, 08:20 PM   #17
the crank is the only drive pulley......all the others are driven by the crank....
-93 2.3 notch (DD)
Old October 13th, 2010, 09:01 PM   #18
1991 Mustang LX 2.3
At that point it probably isn't charging much since at 750 rpm the alternator is spinning as it would be at 525 rpm, and that still throws a charge, just not a strong one.
The battery can more than handle the low charge to discharge for the brief amount of time one spends at that low an rpm in those conditions. Typically an engine doesn't idle like that for more than 5 minutes without some type of rpm increase.
On my modded ZX2, I run a 40% underdrive pulley at the crank and other than a little dimming of the headlights at idle, all is fine. Now if you have a audio system that requires a 200 am alternator and 80 amp fuses on it, well underdriving isn't for you.
But look at it this way, if you underdrive, your car is now a hybrid!
It is using battery power to offset the low charging output under limited driving conditions. Tell your eco friends you're helping to save the environment by using battery power to keep your engine running at idle which saves gas.
Rob
http://zxtuner.com
Old October 13th, 2010, 09:06 PM   #19
1991 Mustang LX 2.3
Ahhh... yes and no.
For example a the oem 87-90 2.3 mustang uses the water pump pulley to turn the a/c compressor, making the water pump pulley the drive pulley for the a/c compressor, which is the driven pulley. The water pump pulley in this case is both a drive and a driven pulley since the second pulley of the water pump is driven by the crank, which is almost always a drive pulley.
Thats the same principle I used on my 1991... except I am driving the alt and power steering from the water pump (drive side) and the crank turns the a/c compressor and the water pump (driven side).
Rob
http://zxtuner.com
Old October 13th, 2010, 10:49 PM   #20
1987 ford mustang
Wow that's cool! So what do you get. Out of this mod?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2-3-mustangs/186269-underdrive-pulley-junkyard-style.html
Underdrive...junkyard style - Ford Ranger Forum This thread Pingback March 20th, 2012 02:09 PM
1993 Mustang LX N/A 2.3L - Page 5 - MustangForums.com This thread Refback December 24th, 2010 01:15 AM
Threads Similar to: Underdrive Pulley - Junkyard Style!
Does this look like a race underdrive crank pulley & stock water pump pulley? STREETFIGHTER50 5.0 Mustangs 8 January 26th, 2010 10:47 AM
Underdrive pulley 06dkkiser 2005 - 2010 V6 10 October 28th, 2009 02:25 PM
underdrive pulley Toph6888 V6 Mustangs 34 February 29th, 2008 03:26 PM
underdrive pulley Baker02125 V6 Mustangs 23 December 25th, 2007 01:20 AM
Underdrive pulley firefly1241 5.0 Mustangs 20 December 9th, 2006 02:13 AM
