interchangeable transmissions
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old October 4th, 2010, 06:10 PM   #1
ocejo's Avatar
92 LX 2.3N/A
ocejo is on a distinguished road
could I use an A4LD from an 88 in a 92 2.3?
Old October 5th, 2010, 01:51 PM   #2
ocejo's Avatar
92 LX 2.3N/A
anybody?
Old October 5th, 2010, 08:19 PM   #3
1991 Mustang LX 2.3
zonker is on a distinguished road
Originally Posted by ocejo View Post
anybody?
i think its ok, just make sure it has the same plugs for the lockup convertor and 3-4 shift solenoid.
Rob
1987 Mustang 2.3 LX Convert (T5) project 2.5 N/A HP
1991 Mustang 2.3 LX Convert (A4LD)
1992 Mustang 2.3 LX Convert (A4LD) 41.52 mpg!!
1994 Capri XR2 1.6 Turbo Convert
1999 ZX2 S/R 2.0 Coupe
http://zxtuner.com
Old October 6th, 2010, 11:14 AM   #4
ocejo's Avatar
92 LX 2.3N/A
well you got me......
Old October 10th, 2010, 09:59 PM   #5
1988 mustang lx soft top
fredstar is on a distinguished road
dudes!!
ima say no, just because its an OD (over drive) transmission, but i can be wrong, you might be able to with more than some mods.
http://www.therangerstation.com/tech...AutoTrans.html
^ thats a link to a site that has all the specs for all the ford transmissions from the late 80's early 90's, hope this helps ya.
my opinion, go t-5!!, heres a sight with specific engine swap details, well put together
http://www.stinger-performance.com/howto.html
Old October 11th, 2010, 10:17 AM   #6
ocejo's Avatar
92 LX 2.3N/A
I'm all for going with a T5 but the low budget and swap time hold me back, I better go look at it personally. The story I was given is that it was bought with an engine for an 88 but the engine was swapped in alone. I'll have to get some part nnumbers and pictures to show you guys, hopefully it's a good one
Old October 11th, 2010, 10:27 AM   #7
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
+1 for going T5. The A4LD is a horrible POS tranny.
That being said, I see absolutely NO reason why an '88 A4LD wouldn't work in a '92 or vice-versa. Near as I know they're the same tranny, and Mustangs didn't go to electronically controlled transmissions until '94 with the bodystyle change (at which point the A4LD was dropped completely).
Function > Form, always
Old October 11th, 2010, 11:25 AM   #8
1991 Mustang LX 2.3
The 91-93 A4LD has electronic controls on 4th and OD, 1-3 is vacuum modulator operated and kickdown is linkage/modulator controlled.
I'm not sure on if the 87-90 are setup that way.
Rob
http://zxtuner.com
Old October 11th, 2010, 05:17 PM   #9
Actually, i take that back, the o/d has nothing to do with the fly wheel and pressure plate settings, nore does it have anything to do with the od settings, because im pretty sure the o/d option is on the shift lever anyway, and is a transmission amenity, not engine, i dont see why i wouldnt fit, i withdraw my first comment, but seriously, just save up and go t-5, i found tons of t-5's for under 250$ on cl from private sellers, got a whole conversion swap from this guy who converted his t-5 to auto for his wife, 300 for everything, trans pedals, weather boot protecter, boot, shifter, mounts pressure plate fly wheel etc, just have to look hard bro, you'll find it if you look, the internets a scary place.
Old October 11th, 2010, 06:12 PM   #10
The trick will be finding the RIGHT T-5. A V8 one won't work because the pilot shaft is too big. I don't know about the ones from behind V6s, and I know any of the ones from other brands won't work (Nissan/GM).
Old October 12th, 2010, 09:05 PM   #11
ocejo's Avatar
92 LX 2.3N/A
here's the part numbers I got from the case
P-86GT-7006-AAR
1-6069-D F8
and from the tail
85GT 7A041 CA
it has an 18bolt pan if that has anything to do with it
Old October 13th, 2010, 03:14 PM   #12
ocejo's Avatar
92 LX 2.3N/A
I'm trying to get my 92 on the road, the problem I have now is that the car won't move at all, I have left the car running for a while in gear and no sign. Oil and filter were changed with no results.
Old November 29th, 2010, 02:43 PM   #13
RaptorF150 is on a distinguished road
I have an '88 LX with a fried auto transmission. Where can you buy this T5 from at the price that is listed on the swap? I think I could pull it off myself and around 400 bucks isn't bad for a new tranny.
Old November 29th, 2010, 08:36 PM   #14
92 mustang gt
brianlepard28 is on a distinguished road
Send a message via Yahoo to brianlepard28
i ahve a ? for yall. i have a 93 with aod i belive its not electric i know. im wanting to put a t-5 in it. what t-5's can i go with and what year models?
Old November 30th, 2010, 10:59 AM   #15
ocejo's Avatar
92 LX 2.3N/A
if its a 4cyl its an a4ld, for a t5 you could use one from a 4, 6, and 8cyl. but to avoid some work just get one from a 4cyl
Old November 30th, 2010, 10:20 PM   #16
92 mustang gt
i have looked for one from a 4cyl but cant seem to find one.
Threads Similar to: interchangeable transmissions
interchangeable injectors black04musclestang 99-04 0 November 25th, 2009 10:55 PM
87/91 rear end interchangeable? rusty2407 5.0 Mustangs 13 August 7th, 2008 09:58 PM
interchangeable 5.0 parts delgadog 94-95 4 June 5th, 2008 11:58 AM
interchangeable control arms? 01GT 99-04 5 June 29th, 2007 02:57 PM
