1987 ford mustang
power steer question How can I get rid of power steering squeek?? Fluids are fine so I don't know what's going on! I hate pulling up any where having people staring at my car ,and not with the.."dammm that's a nice paint job there ei" any ideas guys ?
1991 Mustang LX 2.3
r u sure it's coming from the power steering bump and not one of the belt idlers or a serpentine belt?
that's what i'd check first. pull the belt and inspect it for dry rot or cracks, and with the belt off spin the idler bearings and feel if they are rough or noisy when you turn them.
Rob 1987 Mustang 2.3 LX Convert (T5) project 2.5 N/A HP 1991 Mustang 2.3 LX Convert (A4LD) 1992 Mustang 2.3 LX Convert (A4LD) 41.52 mpg!! 1994 Capri XR2 1.6 Turbo Convert 1999 ZX2 S/R 2.0 Coupe http://zxtuner.com
1987 ford mustang
I checked belts and pulleys. Plus the squeek only happens when I move the steering wheel. Other than that it just a nice idle prrrr from the motor
#4 | |
1991 Mustang LX 2.3
it sounds like the belt is slipping when the pump is required to work. causes: 1. bad tensioner 2. belt length too long 3. belt has oil or some other crap like belt dressing on it and its slipping because its no longer clean and dry.
2003 v6 Stang
20.61@60.28
i am having this exact same problem! Tell me what you find out 87
1987 ford mustang
It's not a high pitch squeek like the belt. It's more like a muffled whine.. does that help better. OK 92
1992 Mustang LX
same thing happens with my 92 lx and also when i turn the wheel it kinda strains the battery i can tell because i can hear the idle go up and the noise comes about its weird....
anyone figure this out?
![]() 92' 2.3n/a LX soon to be 2.3T SVO Clone |
1988 2.3L Hatch
Ha-Ha
Take a look at the ball joints. When they dry up it causes the power steering to work harder.
1992 Mustang LX
alright where would those be located? got a pic? lol
Hahahaha i think what you are hearing is the classic ford P/S pump whine. Is it a mixture of almost a whine and a growl? If so thats your problem. It is not fixable. I dont know what they did wrong, but they designed the pump in a way that it just makes noise under a load. And when they do it at idle, it means they are low on fluid.
1991 Mustang LX 2.3L 5 Speed convert 1989 Ranger 4X4 2.3L 5 Speed Entire turbo kit waiting to be used again. |
Threads Similar to: power steer question
| Roll steer | wdr | 4V / SVT | 9 | May 27th, 2009 12:44 PM |
| Pump it, Steer it | Zak | Classic Mustangs | 1 | June 15th, 2008 02:45 AM |
| Bump steer | mustang fanatic | 2005 - 2010 | 7 | December 15th, 2007 02:04 PM |
| bump steer kits?!?!? | noppe180 | 96-98 | 1 | June 12th, 2007 11:08 AM |
| Bump Steer | stang94 | 94-95 | 2 | April 21st, 2007 07:20 PM |
