92 LX 2.3N/A
no temp reading and no e-fan
I noticed that the temperature gauge does not rise, and the electric fan only runs with the a/c on. Anyone know what controls these two, a search brings up a temp sensor and a temp switch
1995 SVT Cobra
there is also the CCRM which is located very close to the passenger side shock tower in the engine bay.
![]() 1995 SVT Cobra #182/4005, 275/305, 217k miles 1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles 1995 Mustang, 3.8L, 233k miles 1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles sold: 1987 GT MM Military Crew Member MM+Cleavage member #21
92 LX 2.3N/A
you think the module could go bad?
1995 SVT Cobra
the module itself has 3 or 4 relays inside. The relays tend to stick; sometimes giving the box a few good hard taps gets them working again.
Supercharged 89'/ 85' SVO
11.945 @ 119.6
On the temp gauge, open the hood of your car, standing on the drivers side, look towards the rear of the engine below the oil sending unit you should find the coolant gauge sensor. It should have a single wire attached to it. If you pull that wire off, turn the ignition to the "on position" and the place that wire to ground (any negative voltage source on the car) your temp gauge should move to full hot. If it does, there is a high probability that you need to replace this sensor.
The fan sensor is located on the intake manifold, on the bottom near the center. Pull the wire off the sensor and place it to ground and see if the fan runs. If it does, ther is a high probability that you need to replace this sensor.
![]() Supercharged 2.7L 398 HP 501 ft lb !! |
92 LX 2.3N/A
tried the ground to the gauge sensor and no movement
1995 SVT Cobra
I hope you meant that you grounded the plug that attaches to the gauge sensor. If you pull the plug and then ground the sensor itself you won't get anything.
92 LX 2.3N/A
yes the plug
1991 Mustang LX 2.3
91-93's don't have a cooling fan switch like the earlier pre-90 mustangs do, theirs is operated thru the engine computer reading the coolant temp sensor (the same one that supplies a signal to the gauge).
the ecu then triggers the relay to send current to the fan. sooo... if both gauge and fan is fubar (without a/c engagement), i'd say your culprit is either the coolant sensor or the wiring itself. you already know the CCRM box is good because the fan came on with the AC engagement, so you can rule that out.
Rob 1987 Mustang 2.3 LX Convert (T5) project 2.5 N/A HP 1991 Mustang 2.3 LX Convert (A4LD) 1992 Mustang 2.3 LX Convert (A4LD) 41.52 mpg!! 1994 Capri XR2 1.6 Turbo Convert 1999 ZX2 S/R 2.0 Coupe http://zxtuner.com
92 LX 2.3N/A
I tried grounding the plug with a tester with a light, that should still get the ground through right
11.945 @ 119.6
Thanks for the correction Rob, I was looking at the 85ish Mustang on Ocejo's avatar when answering his question, didn't read his car description.
![]() ![]() Ocejo, I'm going to post a wiring diagram for you to take a look at, so you can trace some wires. Give me a little time to dig them up.
92 LX 2.3N/A
thanks
92 LX 2.3N/A
I'm bringing this thread back now that I have the car running again. Any luck on the diagram OHC230? still no fan or gauge reading......
FK UR HONDA
hey i have that schematic in my eec for noobs thread ocejo
Nitrous is neat.... Fuel injection is sweet... but at the end of the day i'd rather be blown 91 Mustang hatch(AT) 91 Mustang hatch 2.3T |
FK UR HONDA
correction theres no diagram fro the coolant switch on the head only the coolant sensor my bad. but ya replace both sensor in the coolant line and the switch on the back of the head i think both combined is like 25-30 bucks i had the same prob and it was the switch on the head. but i also replaced the 20 year old cts too and my car runs cleaner now
92 LX 2.3N/A
is there a way to test the switch by the firewall?
FK UR HONDA
test the coolant switch on head by grounding the wire going to it with the ign on and theres a sequence of tests for the cts in the heater hose but really that one only effects rich and lean not temp on the gauge
1991 Mustang LX 2.3
ohmmeter and a handheld temp reader...
FK UR HONDA
ya i know that but its a pain in the ass that way id rather spend 15 bucks and skip that step lol
92 LX 2.3N/A
I guess I'll just grab a new temp switch
Threads Similar to: no temp reading and no e-fan
| Normal temp reading? | copracr | 5.0 Mustangs | 3 | October 29th, 2010 11:26 PM |
| mach one fan temp | Bad02gt | 4V / SVT | 5 | September 7th, 2010 10:11 PM |
| rough idle / no temp reading / high pitch whine after intake manifold replacement | brianallman | 96-98 | 1 | August 20th, 2010 02:16 AM |
| temp sensor/fan switch | hockey | 2.3 Mustangs | 7 | July 28th, 2010 03:10 PM |
| whats the normal temp gauge reading? | 03snakeminated | 4V / SVT | 4 | September 2nd, 2008 11:43 AM |
