#161 |
If you want power and reliability and would like to stay N/A just go to esslinger and order their crate ministock engine that makes 225 hp.
1991 Mustang LX 2.3L 5 Speed convert 1989 Ranger 4X4 2.3L 5 Speed Entire turbo kit waiting to be used again. |
#162 | |
1991 Mustang LX 2.3
another thought thats crossed my warped brain (and is filed in the "what if" drawer) is what if you turned one of the engines own cylinders into an air pump and made it function as an air compressor, with a remote air tank that would store that cylinder's pure air charge and be designed to deliver the compressed air into the other "active" cylinders on load demands...
Rob 1987 Mustang 2.3 LX Convert (T5) project 2.5 N/A HP 1991 Mustang 2.3 LX Convert (A4LD) 1992 Mustang 2.3 LX Convert (A4LD) 41.52 mpg!! 1994 Capri XR2 1.6 Turbo Convert 1999 ZX2 S/R 2.0 Coupe http://zxtuner.com
#163 |
1988 Mustang LX coupe
The front fenders and rear quarters although smoothed out somehwat look like the Capri body panels ... I had to throw in my penny's worth ... You guys have just gotten way to dang smart ...
88' coupe 5spd ...
#164 | |
MM's king of Neon's
404 - car not found
17.81@87
...and I'm pretty sure after this discussion Ford should hire the 3 of us onto SVT.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
#165 |
Supercharged 89'/ 85' SVO
11.945 @ 119.6
If you want power and reliability and would like to stay N/A just go to Esslinger and order their crate ministock engine that makes 225 hp
You have a good point. I really think that you get a lot of motor for $8,000 and it is a true racing engine, with a LOT of detail work added, which might be taken for granted by someone who isn't all that familiar with these racing engines. But....if you are married like me and you tell your wife that you want to spend $8 grand on a motor for your car and you might not be able to drive on the street, it may cause some fricton. ![]() I think that is a good reason to pursue more financially moderate ways to have your fun, like turbo or supercharging. I really think that the supercharger set up I'm working on, will give an honest 50-60 HP boost to a mostly stock 2.3 engine, without destroying the driveability of the car.You guys have just gotten way to dang smart ... Not me Todd, I just keep getting dumber!
![]() Supercharged 2.7L 398 HP 501 ft lb !! |
#166 |
#167 |
11.945 @ 119.6
While I hear what you guys are saying about the Esslinger crate motors, I think for a street driven car, where you don’t have to worry about class rules, building a more tame 2.7L motor makes a lot more sense to me, money wise. That extra displacement buys you quite a bit of extra torque, at a much lower RPM and with the same HP goal in mind, it is feasible to run a less aggressive cam profile in the larger motor.
I think I paid about $1900 dollars a piece for my 2.7L cranks; I bought 2 at one time. I paid about $2,000 for my completely assembled Esslinger SVO head/with cam and about $1,300 for the rest of the parts plus some balancing work to build my current motor, using the stock block. If we round that off to an even $5,500, we are still $2,500 ahead of the game when you are comparing the Esslinger crate, to a DIY/ Esslinger motor. I don't have a current dyno result to post on the 2.7L in my car, but I can tell you that it has gained huge amounts of torque over the 2.3L crank.
![]() Supercharged 2.7L 398 HP 501 ft lb !! Last edited by OHC230; March 10th, 2011 at 12:19 AM. |
#168 | |
#169 |
11.945 @ 119.6
You could expect to see a gain of about 30-40 HP with the larger displacement and a similar percentage gain in torque.
#170 |
any updates on this?
#171 |
11.945 @ 119.6
Yeah I have a bunch of them Brandy, but it will take me a while to sort through all the data. The good news is: I have come up with a low cost JY supercharger swap for the 2.3 engine, which works way better than I thought it would. I will fill in the details later. I have some more testing to do first.
#172 |
MM's king of Neon's
404 - car not found
17.81@87
@ junkyard supercharger. I might have to get a 2.3L car.Very interested in the data of course. Do you have basline data? ...after this of course...
#173 |
11.945 @ 119.6
Yeah I have basline test data on a few 2.3L motors, but enough of that, what's the picture of? Is this the new mill for your ride?
Captions for photo's please!
#174 | |
MM's king of Neon's
404 - car not found
17.81@87
New FR500 cams are going in soon. Which brings me to my next point, cam profiles. What cam profile are you using? Turbo and positive displacement supercharger are two dramatically different profiles. You could either favor one or the other based on whether you wanted top end power or bottom end torque, or you could try and balance them. ...and what LSA would you reccommend for a positive displacement supercharged engine?
#175 |
11.945 @ 119.6
I recognized the Cobra motor, but I asked if it was yours?? Y/N
Snake you are right about the cams. The exhaust events on turbo cams are not always optimal for supercharged engines. Most of my dyno tuning experience with supercharged engines is either from Porsches or earlier Mustangs, although I have worked with some later model stuff as well. Some consistent observations lead me to think that most factory cam profiles are adequate for 90% of the street motors out there. You are probably looking for that last 10% aren’t you? If I had to narrow this down, I would look for a split profile cam with a duration of 210-214/225-228 and 12-14 degrees of lobe separation angle. Both Crane and Comp Cams offer grinds close to this. I’ve seen pulls of 810 HP and close to 800 ft/lb from Cobra motors with these specs and your Eaton blower and 50 HP less than this on the 3 valve versions. You will need 80 PPH injectors and 2 monster fuel pumps to keep up with this. Don’t bank on the FMU for tuning this, I’m sure that you probably know this all ready.
#176 | |
MM's king of Neon's
404 - car not found
17.81@87
I've got the FR500's which are 214/209 duration 0.472 lift, and since it's DOHC I'll be setting the LSA. I'd be shocked to see an Eaton M112 blower top out in the 800's, but I don't think it would be unreasonable with a TVS. I'm going 60lb/hr, twin GT fuel pumps, dual FPDM, and shooting for 550hp.Still eager to see your data. I'd especially be interested in the final intake charge temperature and the intercooling package heat rejection capabilities.
