turbo help
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old November 28th, 2010, 10:02 PM   #1
92 mustang gt
brianlepard28 is on a distinguished road
Send a message via Yahoo to brianlepard28
turbo help
ok as many of u knwo i have been looking at just upgrading a 2.3 but i think plans have changed a bit. im leaning more towards a turbo. im keeping the engine that i was going to re build but going to make it turbo. i have a couple of concerns. im going to replace everything with forged parts but can i take svo parts like upper and lower intake and manifold. will it all bolt up or is it diff? will anything from Merkur XR4Ti work.
thanks for any help i can get.
Old December 16th, 2010, 12:20 PM   #2
92lxstangOre's Avatar
1992 Hatchback LX 5.0
92lxstangOre is on a distinguished road
As far as i know, everything is similar with the '84-'86 SVO's, '83-'88 TC's, and the turbocougs. Some of the intakes are better then the others but you can try some of these sites:
NATO - North American Turbocoupe Organization - NATO has just about every bit of information you could want on the TC's and I'm sure they have info about the SVO's. Only problem is they want $20 for you to join, I say, F that for now LOL
Fox T-Bird/Cougar Forums - They have all kinds of birds and cougs but they help out still
Ford 2.3 Forums - This site's kinda dead but you could find some information there possibly!
COOL****CATS ::****The 1983-88 Mercury Cougar - They are all about the turbo cougs so it might be of some help
Just thought i would try to help some since no one else has posted I hope you figure some things out!
-Ben
Old December 28th, 2010, 11:49 AM   #3
2003 Mustang GT
motormenace is on a distinguished road
All of the intakes do interchange. The NA ones are the same also. The only changes have been the knock sensor hole and one or two things not drilled. Same casting numbers even. Under force induction, there's not much differance in these intakes....well, till you port them.
Threads Similar to: turbo help
Dyno results from new CEA 67mm Billet Turbo from Precision Turbo 499whp 552wtrq 13psi Turblow 99-04 18 November 9th, 2010 09:12 PM
Mellon's Twin Turbo Stealth vs Wills99z's Single Turbo z28 Mellon Videos 10 December 30th, 2006 10:05 AM
Super Charger vs Turbo/Twin Turbo: Pros and Cons of each FireryDriver 2005 - 2010 9 September 17th, 2006 04:15 PM
