help w/running prob please
i got a 93 5spd 2.3l with a auto ecu in it and it has running problems
idles fine and wot is o.k. but under 2500 rpms it starts cutting back and bucking under a load (also hard to start spins over too long) it has new autolite wires and plugs new 02 sensor new fuel filter coil packs have been changed with different coils (used) changed maf (new) changed ign module (used) changed baro sensor (used) new timing belt fuel press 35 line connected and 44 disconnected vaccuum is at 18lbs idling fuel press reg holds vaccuum (checked with handheld vaccuum pump) could the crank sensor be causing this?
ive found that if i unplug the coil that fires the exhaust plugs it seems to run fine
not sure what direction to go in crank sensor is 120 bucks and thats a pricey guess but ive darn near tried everything else
1991 Mustang LX 2.3
egr valve? egr vacuum solenoid?
Rob 1987 Mustang 2.3 LX Convert (T5) project 2.5 N/A HP 1991 Mustang 2.3 LX Convert (A4LD) 1992 Mustang 2.3 LX Convert (A4LD) 41.52 mpg!! 1994 Capri XR2 1.6 Turbo Convert 1999 ZX2 S/R 2.0 Coupe http://zxtuner.com
ive disconnected the egr and plugged off line and it runs the same
1991 Mustang LX 2.3
octane plug in its right place?
tps voltage correct? any codes? spout connector plugged in? done a eec reset to see if that helps?
tps is good i checked with a volt meter also checked entire range of sensor to check for dead spots
ecu reset doesnt help no codes ive seen 2 spout connectors and they are both there
FK UR HONDA
id start with a fuel pressure check because at wot a slight vacuum is drawn through the fuel system but at lower vacuum levels it could be running lean should be 40psi.
the crank sensor a dis module alone control timing and coil control they usually dont throw codes until complete failure. but until they do they cause chaos. start by replacing them i know its expensive but its mentioned in every ford TSB they are prone to failure. u can usually find them cheap on ebay |
i checked fuel press it was 35 with vac line connected and 44 disconnected
when i first turn key on and pump primes press is at 40 (engine off)
1991 Mustang LX 2.3
any codes?
timing belt alignment marks correct?
FK UR HONDA
then id start with the ignition like i said . also check for vss(vehicle speed sensor) codes. i had a vss going out on me and it ran really funky, missing and stalling. the vss comes out of the tranny were the spedo cable goes in.
also you stated if you unplug the exhaust coil it runs fine right? have you checked the firing order? also how hot are your coils and dis getting? you should try to keep them as cool as possible |
93 Mustang LX 2.3 T-5
where would the octane plug be located on a 93 lx? I didnt think N/A cars had octane plugs...
93 2.3l LX U.S. 15x7 ten hole rims Calypso green Moates QH T-5 Conversion Dual 2.5" Exhaust with Thrush Welded muffler
1991 Mustang LX 2.3
rh side of firewall, on harness
crank sensor cured prob
FK UR HONDA
told ya
well it was kinda a easy guess seeing as how ive replaced everything up to that point so the crank sensor was a no brainer
i put off replacing crank snesor cause i had no way of getting a used one....without air tools accessable its hard to get one off a junk car...all the other parts was a easy swap so i was just trying to avoid spending a 100 bucks if i could...i returned all the other parts that didnt cure it so no loss there
#16 | |
but you told me i guess
92 LX 2.3N/A
is there a way to check a crank sensor?
FK UR HONDA
not that i know of swap a new one in hahaha
92 LX 2.3N/A
I've got a different problem though, no start. I just took the IRCM into autozone and passed ok, replaced and ignition module on strut tower and both coils with known good ones. I've checked for spark, none.
FK UR HONDA
so you replaced the "black box" on the pass side fender, DIS and the coils with known good ones correct? have you tried a crank sensor, fusable links, the park neutral position switch? on a side note there is a special tool to check the crank sensor.
Threads Similar to: help w/running prob please
| ecu question w/running prob | wick22 | 2.3 Mustangs | 0 | December 10th, 2010 11:20 PM |
| 2002 gt not running??? had multiple missfires not running!! | foxcruzin91lx | 99-04 | 8 | July 20th, 2010 03:00 PM |
| prob | mpboy | 99-04 | 1 | March 5th, 2008 09:46 PM |
| Help GF Prob | Till | The Clubhouse | 53 | February 25th, 2008 10:20 PM |
