1989 Mustang
turbo cam
can i put a turbo cam in my 2.3 Does anyone know what size the "big" turbo cam was?
600 dollars, a taillight and windshield. 4 cylinder auto, soon to be a turbo car!
1989 Mustang
car is n/a
Supercharged 89'/ 85' SVO
11.945 @ 119.6
I take it you are planning to run a turbo or supercharger?
Turbo cams Cam Lift (Intake):.244" Cam Lift (Exhaust):.244" Valve Lift (Intake):.422" Valve Lift (Exhaust):.422" Degrees Overlap:46 Deg Advertised Duration (Intake):268 Deg Advertised Duration (Exhaust):268 Deg Duration at .050" Lobe Lift (Intake):197 Deg Duration at .050" Lobe Lift (Exhaust):196 Deg Cam Timing at .050" Lobe Lift (Intake Open):22 Deg After Top Center Cam Timing at .050" Lobe Lift (Exhaust Open):39 Deg Before Bottom Center Cam Timing at .050" Lobe Lift (Intake Close):39 Deg After Bottom Center Cam Timing at .050" Lobe Lift (Exhaust Close):22 Deg Before Top Center Valve Lash (Intake):Hydraulic Valve Lash (Exhaust):Hydraulic Lobe Centerline (Intake):110 Deg Lobe Centerline (Exhaust):112 Deg Cam Lift (Intake):.238" Cam Lift (Exhaust):.238" Valve Lift (Intake):.412" Valve Lift (Exhaust):.412" Degrees Overlap:28 Deg Advertised Duration (Intake):248 Deg Advertised Duration (Exhaust):250 Deg Duration at .050" Lobe Lift (Intake):187 Deg Duration at .050" Lobe Lift (Exhaust):189 Deg Cam Timing at .050" Lobe Lift (Intake Open):23 Deg After Top Center Cam Timing at .050" Lobe Lift (Exhaust Open):39 Deg Before Bottom Center Cam Timing at .050" Lobe Lift (Intake Close):30 Deg After Bottom Center Cam Timing at .050" Lobe Lift (Exhaust Close):30 Deg Before Top Center Valve Lash (Intake):Hydraulic Valve Lash (Exhaust):Hydraulic Lobe Centerline (Intake):108 Deg Lobe Centerline (Exhaust):116 Deg
![]() Supercharged 2.7L 398 HP 501 ft lb !! |
1989 Mustang
Car is non aspirated.
FK UR HONDA
haha car is NON ASPIRATED huh? hmm deos that mean it deosnt run lol.
i think you mean normally aspirated
Nitrous is neat.... Fuel injection is sweet... but at the end of the day i'd rather be blown 91 Mustang hatch(AT) 91 Mustang hatch 2.3T |
#6 | |
1989 Mustang
oh damn turbos
FK UR HONDA
just go get some thing like this70-123-6 - High Energy? Hydraulic Flat Tappet Camshafts
turbo cams are meant for turbo apllications you wont be happy with one on a n/a
1989 Mustang
Price: $253.14
Am i needing valve springs too? Even though i wont be happy with the turbo cam, can i still use it?
11.945 @ 119.6
Price: $253.14
You must not read other posts. You can buy a roller cam for $225.00 which is designed for N/A motors for less $$ than that flat follower cam and then go to the local Pick and Pull yard and grab a set of roller followers out of a dual plug 2.3L and you will actually see a difference in performance. Am I needing valve springs too? Not necessarily, unless yours are in poor shape (lot of miles on them). With either the turbo cam or the Comp cams grind, you will need new flat followers. They sell for roughly 80 bucks and MUST be changed when replacing the cam. Even though I won’t be happy with the turbo cam, can I still use it? You could if you wanted an engine that bogs when you step on it, which is typical of the performance you get with these types of cams when they are used without a turbo. Your car would likely accelerate more slowly with the turbo cam, depending on which one you have. If you are trying to slow your car down, there are easier ways. For a good roller cam, follow this link------>Cam Questions!
Threads Similar to: turbo cam
| Dyno results from new CEA 67mm Billet Turbo from Precision Turbo 499whp 552wtrq 13psi | Turblow | 99-04 | 18 | November 9th, 2010 09:12 PM |
| Turbo timers and Boost Controllers? Turbo guys where you at? | 95StangSVT | General Tech | 14 | July 11th, 2008 07:01 AM |
| Mellon's Twin Turbo Stealth vs Wills99z's Single Turbo z28 | Mellon | Videos | 10 | December 30th, 2006 10:05 AM |
| Super Charger vs Turbo/Twin Turbo: Pros and Cons of each | FireryDriver | 2005 - 2010 | 9 | September 17th, 2006 04:15 PM |
