a4ld tranni questions
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old January 5th, 2011, 08:01 AM   #1
1990 Mustang LX 2.5/auto
18s?(wild guess)
ZebLX90 is on a distinguished road
so i have a mustang 2.3 with an a4ld and the trans in it is blown out
and i heard that you could get a a4ld out of a later model v6 and make it work on my car
also there supposed to have more clutches and a stronger planitary gear in them, what i wanna know is what it would take to make one fit on my motor
do i need my bell housing or my tourque conveter?
if any one has any answers it would be much appreciated
Old January 5th, 2011, 07:17 PM   #2
free2.3's Avatar
FK UR HONDA
free2.3 is on a distinguished road
yes the strongest tranny is the a4ld out of 4.0l ranger or exploder youll have yo change the bell/pump and torque converter. i a have a 3.8 a4ld in my 91
Nitrous is neat.... Fuel injection is sweet... but at the end of the day i'd rather be blown
91 Mustang hatch(AT)
91 Mustang hatch 2.3T
Old January 5th, 2011, 08:50 PM   #3
18s?(wild guess)
does it matter what year in paticular?
and thanks alot
Old January 6th, 2011, 02:22 AM   #4
free2.3's Avatar
FK UR HONDA
kinda the strongest are the 96 4.0l a4ld because in 97 the switched to the 4r55s just keep in mind as the power level and vehicle weight goes up so deos the transmissions strength so try to find a big v6 trans like the 4.0 or you could always go through the trans your self heres a good write up the guy spent like 900 on parts after all was said and done but he also started with a 4.0 wich has more clutches a welded planetary and a one piece steel od drum heres one of my old threads with links to his rebuild how to rebuild your a4ld
Old January 6th, 2011, 09:24 AM   #5
18s?(wild guess)
i thought about just rebuilding mine but i figure if theres better stronger parts out there i might as wel get them now
but thanks alot for the answers
Threads Similar to: a4ld tranni questions
A4LD problems... Cgross609 2.3 Mustangs 28 January 27th, 2011 01:41 AM
how to rebuild your a4ld free2.3 2.3 Mustangs 0 December 5th, 2010 12:30 AM
a4ld problems bubbatheroo 2.3 Mustangs 10 August 1st, 2010 11:13 PM
Help Wanted: A4LD to T-5 Swap! Nitrous-Junky 2.3 Mustangs 2 July 16th, 2010 07:34 AM
A4LD to T5 conversion 88FLvert 2.3 Mustangs 6 June 28th, 2008 02:21 PM
