#41 |
unstoppable @ speed of light
From what I know they are a better turbo than an IHI.
This is off of Stinger website. Good read on his FAQ page. Lost more info about things other than turbo's as well. What turbo should I get for "X" hp? -Stock (87-88 Turbo Coupe) Ishi-Warner IHI: Less than 250rwhp, super quick spooling (full boost at 1800-2000 rpm with a few airflow mods) but runs out of steam at higher engine speeds. Great for heavy cars or daily drivers. Good to 18psi or so. -Stock (83-86 Mustang/Turbo Coupe, 84-89 Merkur) Garrett/AiResearch T3: Up to about 300rwhp. Full boost at 2500 rpm or so with a few airflow mods, pulls pretty well up top. Has a very hard "kick" when boost kicks in. Great for a daily driver/street terror with minor mods. Good to 23psi or so. -T3/T4 Hybrid T04E 46 trim compressor/Stage III exhaust side with .48 a/r for street cars, .63 a/r for street/strip. Great for engines in the 250-350rwhp range. Full boost at 3100rpm or so with a header and supporting mods. Nice linear power throughout rpm range. Great for street/strip cars in the 12-13 second 1/4 mile range. Good to 25psi or so. -T3/T4 Hybrid T04E 50 trim compressor/Stage III exhaust side with .48 a/r for street cars, .63 a/r for street/strip: Great for engines in the 300-430rwhp range. Full boost at 3300rpm or so with a header and supporting mods. Nice linear power throughout rpm range. Great for street/strip cars in the 11-12 second 1/4 mile range. Good to 35psi or so. -Holset HY35: Great for engines in the 300-480+rwhp range. Full boost at 3600rpm or so with a header and supporting mods. Pulls like a freight train in the higher rpm range. Great for street/strip cars in the 10-12 second 1/4 mile range. Loves 30+psi of boost. -Holset HE351: Slightly upgraded version of HY35. Great for engines in the 300-480+rwhp range. Full boost at 3600rpm or so with a header and supporting mods. Pulls like a freight train in the higher rpm range. Great for street/strip cars in the 10-12 second 1/4 mile range. Loves 30+psi of boost. -Holset HX35: Great for engines in the 380-500rwhp range. Full boost at 3800rpm or so with a header and supporting mods. Pulls like a freight train in the higher rpm range. Great for street/strip cars in the 10-11 second 1/4 mile range. Loves 30+psi of boost. Split scroll exhaust housing causes boost control problems unless an external wastegate is used or the divider is cut out. -T61: Great for engines in the 400-600rwhp range. Full boost at 4000rpm or so with a header and supporting mods. Great for serious street cars or drag cars in the 9-10 second 1/4 mile range. Can handle upwards of 40psi. -There are also many new GT series turbos that will work on 2.3T applications. I did not include them because they are a much more expensive turbo and since they have many more options available, they should be spec'd out specifically for your setup.
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end. |
#42 |
2004 Mustang Convertible
Yeah I have the FAQ bookmarked and I look at it daily it seems.
I am not sure I understand the term "trim" is my turbo the 50 trim or I thought it was 57 trim. So stinger seems to think my turbo is good up to 35psi?
![]() 2004 Convertible - SOLD 1999 Coupe - SOLD 1966 Coupe - SOLD 1987 TurboCoupe - Cut in prices! 1970 Coupe - Soon to be 140 Turbo! 1984 El Camino Conquista - moving truck 2011 Convertible V6 Base 2012 Coupe GT Premium 5.0 Baby! |
#43 |
Couldn't say unless you can positively ID which turbo it is. Sorry I'm not much help with that part!
#44 |
Im starting to think perhaps it really is just an ebay turbo... maybe I will sell it to a honda guy for what I paid and find a real turbo.
#45 |
1988 2.3L Hatch
Ha-Ha
Trim has to do with the ratio between the impeller diameter and the intake hole size. Example: a 50 trim would have a 3 in hole and a 6 in wheel.
#46 |
So I am starting to get too far ahead of myself buying and researching new parts and I am slacking on the small details. Ive got an oil and a coolant leak, power steering pump needs to be replaced and I still havent hidden the wiring in the fenders. Im going to stop buying stuff and get this car to 100% as it is, also need to do some body work before I paint it. Ugh... the slow boring stuff now.
#47 |
Nice lil build, keep it up. I highly recommend lining everything out real good before going to town modding things especially if using stock ECU and sensors they can be very finicky. I also may have some things you may be interested that came off my old setup. hy35 turbo, stinger manifold, tial 38mm WG, 3in stinger downpipe...
Need anything just PM, I know these 2.3T's pretty well. |
Threads Similar to: Thunderstang 2.3 Turbo Build and Questions
| Turbo Build! | Scott2001GT | 99-04 | 36 | July 10th, 2010 10:17 PM |
| Turbo build | Willy Mo | 99-04 | 4 | January 22nd, 2010 02:50 AM |
| turbo build | Hunt_chevs | 5.0 Mustangs | 16 | January 19th, 2010 11:02 PM |
| My turbo build | 98 cobra | 4V / SVT | 5 | June 16th, 2008 12:19 AM |
| Turbo Fox V6 Build: Questions/Ideas? | 83rustling | V6 Mustangs | 17 | December 6th, 2007 12:21 PM |
