Pissed, 93 stang broken interior door handle.
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old March 2nd, 2011, 06:59 PM   #1
1995 SVT Cobra
Cobraman1024 is on a distinguished road
I had a problem with water leakage at the top of my drivers door so I replaced the door hinge pins when I noticed the door was sagging. The leak was still there so I replaced the weatherstripping on the door opening. Right after that I got in the car and went to reopen the door, except it wouldn't open from the inside and I ended up breaking the inside door handle right off the door. The drivers door apparently is still sagging too.
What I need to know is if I can replace just the handle and its spring (old spring broke too along with the holes that the inside handle snaps into which is plastic) or is this a mjor assembly that needs to be replaced?
1995 SVT Cobra #182/4005, 275/305, 217k miles
1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles
1995 Mustang, 3.8L, 233k miles
1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles
sold: 1987 GT
MM Military Crew Member
MM+Cleavage member #21
Old March 4th, 2011, 09:56 PM   #2
1991 Mustang LX 2.3
zonker is on a distinguished road
just the handle assy should suffice.
i found that the handles and linkages work much easier if you have the plastic bushing intact on the door latch striker bolt. just a tip...
Rob
1987 Mustang 2.3 LX Convert (T5) project 2.5 N/A HP
1991 Mustang 2.3 LX Convert (A4LD)
1992 Mustang 2.3 LX Convert (A4LD) 41.52 mpg!!
1994 Capri XR2 1.6 Turbo Convert
1999 ZX2 S/R 2.0 Coupe
http://zxtuner.com
Old March 15th, 2011, 01:01 PM   #3
1995 SVT Cobra
Plastic bushing on the striker bolt?
I don't think I've ever seen a plastic bushing on any of the Fox cars that I've come across. I know that LRS offers them but for some reason "band-aid fix" in bright neon letters showed up as thats what I thought that was. Their description seemed to imply that the bushing was only there as a band aid fix. I'll definitely see if I can find them on some junkyard cars though.
the interior door handle assembly itself was a ridiculously easy replacement.
sold: 1987 GT
Old March 23rd, 2011, 02:05 AM   #4
1991 Mustang LX 2.3
the bushings were oem and your car had them when new. They do break over time and when they do they leave a loose fitting door, which many people, unknowing that the bushing is gone, adjust the striker so the door closes tight.
BUT whan that is done, it creates a need for more pressure to be exerted on the door handle, which then causes the handle to break.
If your car doesn't have them, u can get a set at any autozone for like 4 bucks. They are made by dorman and the pack contains 4 bushings. 2 are the size you need and 2 are not.
Rob
http://zxtuner.com
Old March 23rd, 2011, 12:40 PM   #5
1995 SVT Cobra
Sweet, thanks!
sold: 1987 GT
Threads Similar to: Pissed, 93 stang broken interior door handle.
Im Stuck, How do you remove the f'in interior door handle??!! Mickey 2005 - 2010 14 February 18th, 2011 01:58 PM
Broken door handle! PhillyGT 5.0 Mustangs 2 June 29th, 2010 01:23 AM
broken door handle 5mustang0 5.0 Mustangs 11 August 19th, 2009 10:46 AM
interior door handle removal ZoomZoomMFer The Clubhouse 4 July 28th, 2008 06:55 PM
Broken Door Handle Texas5.0 5.0 Mustangs 33 March 6th, 2007 12:56 PM
