#21 |
you still need a scope to see the switching pattern. Min max will only give you those values. It is impossible to get a correct and acurate pattern without a scope. If the shops you go to test them without a scope (be it on a scan tool or scope) i would stop going there....
1991 Mustang LX 2.3L 5 Speed convert 1989 Ranger 4X4 2.3L 5 Speed Entire turbo kit waiting to be used again. |
#22 |
1995 SVT Cobra
So I finally got rid of the 172 code today.
I figured I'd try the correct 5-speed ECU for my '93 and found one for $25 at a local junkyard. Although the A4LD computer allowed the car to run, I was still going to get the 522, 629 and 566 codes that are A4LD specific. I put in the 5-speed computer and obviously didn't get the A4LD codes anymore but even after driving for 7 miles, shutting the car off, restarting and driving for another 6 miles, still no 172 code showing up. The final test would be waiting until the car has completely cooled down and restarting and driving it which I'll do later tonight. On another note, I also solved the airbag light and code 51 (internal fuse open because of internal short)......Opening the airbag diagnostic box showed me that the fuse was perfectly fine. I replaced it with another diagnostic box but that one showed code 34 (drivers airbag low resistance). I replaced it with a third diagnostic box and it was all good, no codes. That diagnostic box was obviously stuck with a false code just like the A4LD ECU.
![]() 1995 SVT Cobra #182/4005, 275/305, 217k miles 1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles 1995 Mustang, 3.8L, 233k miles 1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles sold: 1987 GT MM Military Crew Member MM+Cleavage member #21
Threads Similar to: Persistent check engine code 172
| Check engine light code | mystof | V6 Mustangs | 0 | October 9th, 2010 11:01 PM |
| Check engine code p171 | orangestang42 | 5.0 Mustangs | 24 | May 29th, 2010 02:16 AM |
| Check engine code help | hippojumqer | 99-04 | 0 | April 22nd, 2010 04:20 PM |
| check engine code 1151 | maverick0817 | 99-04 | 0 | October 24th, 2009 12:13 PM |
| Check engine light code | adam0421 | 2005 - 2010 | 2 | September 28th, 2008 12:05 PM |
