1995 SVT Cobra
Persistent check engine code 172
This code is stuck in the memory of my 93 2.3L with 5-speed. I've tried a bran new junkyard O2 sensor, replacing all vacuum lines at the PCV, throttle body, vac tree, fuel pressure regulator and brake booster. tightened the EGR sensor to the upper intake (bolts slightly loose), tightened the cap over the EGR pirt on the header (filled with a penny) and filled the port on the EGR itself with a dime. No leaks that I can see. I also Seafoamed the engine with half a can and the other half went in the gas tank.
Any other ideas?
![]() 1995 SVT Cobra #182/4005, 275/305, 217k miles 1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles 1995 Mustang, 3.8L, 233k miles 1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles sold: 1987 GT MM Military Crew Member MM+Cleavage member #21
1991 Mustang LX 2.3
some thoughts:
1. iat sensor resistance too low 2. ect sensor resistance too low 3. lack of egr is filling the cylinder with more O2 but the same amount of fuel compared with a working egr. 4. tps is out of adjustment 5. "junkyard" o2 sensor belongs back in junkyard 6. clogged fuel filter 7. low fuel pressure
Rob 1987 Mustang 2.3 LX Convert (T5) project 2.5 N/A HP 1991 Mustang 2.3 LX Convert (A4LD) 1992 Mustang 2.3 LX Convert (A4LD) 41.52 mpg!! 1994 Capri XR2 1.6 Turbo Convert 1999 ZX2 S/R 2.0 Coupe http://zxtuner.com
#3 | |
1995 SVT Cobra
2. ECT; Not sure where this one is located, I know where it is on a 5.0 engine but shouldn't be too difficult to find it. 3. wouldn't the computer compensate for this? 4. might be out of adjustment but at least I know it isn't bad lol.....I'll check the idle voltage though. 5. junkyard O2 sensor; the sensor I pulled looked like it had been in the exhaust pipe for literally less than 100 miles, not one trace of carbon or residue on the metal tip at all and it was perfectly clean, no dirt on the wiring harness or anything. 6. brand new fuel filter installed back in October, only 4000 miles on the car since it was installed. 7. low fuel pressure would be one of three things; clogged filter, clogged regulator or weak fuel pump. add to it a clogged or weak fuel injector(s). I could probably throw a mechanical fuel pressure gauge on the fuel rail and check the pressure to rule out the pump and regulator but its difficult to check pressure while the engine is under load. The CEL won't come on if the engine is just idling. only after about 5 minutes of driving will it light up.
1995 SVT Cobra
Ok so I replaced the IAT and then I found a vac line disconnected from the top cover of the air filter box so I reconnected that. There are two nipples on that cover next to each other. The loose vac line connects to one of them, where does the connection for the other one come from? Possibly the charcoal cannister?
I also found a broken green plastic line but where it was broken was covered up with the black corrugated tubing that is used as a harness I guess for several of these tubes together. I reconnected the ends with a piece of rubber hose and the car still runs the same; CEL is still turning on after about 5 miles of driving. Gas mileage is still 28-30mpg. I just have this annoying CEL with code 172 and still haven't found the cause of it yet. 1. Haven't checked fuel pressure yet; need to find a guage for that. 2. Didn't change out the ECT yet> this sensor is connected in line with a heater core hose right? threaded into a metal t-tube that goes between two rubber hoses? 3. have not checked TPS voltage yet, completely forgot to verify that.
#5 | |
1991 Mustang LX 2.3
one nipple goes to a manifold vacuum source via a plastic line that is black and joined with the green vacuum line behind the corrugation on the firewall. the other nipple is connected to the hose that goes to the hot air diaphragm itself.
1995 SVT Cobra
Must have disconnect that one for the flap when I yanked out the airbox. I'll take care of that when I get home tonight, thanks!
#7 | |
1995 SVT Cobra
Zonker, this quote is from your post about the guy with the "no e-fan, no temp gauge" thread:
Also, the TPS voltage is normal; .95 or .97 or something at idle, forget which but I remember when I checked that it wasn't out of the normal range for idle. Only thing I haven't checked yet is the ECT. I tried just removing it from the metal piping section that its screwed into near the heater core at the firewall but that damn thing is going to be a bitch to remove if it turns out bad. I'll check the resistance of it tomorrow when the engine is cold and when its warmed up after driving to pick up my new clutch cable from Advance. I was shocked at how many broken strands there were on the factory cable when I got under the car yesterday lol........
1995 SVT Cobra
I checked the ECT with the engine cold; 58.85 kohms I think.
With the engine warmed to the needle just on the bottom hash mark for 'normal' I got 3.75 kohms so I think the ECT is working perfectly fine. The IAT reads 14.15kohms and rising with the running.
1995 SVT Cobra
Add "new oxygen sensor" to the list of shit changed. I couldn't get a switching reading off the old one and I can't get a switching reading from the new one either.
Only thing left is the fuckin' computer. I'm sick of chasing this shit.
1991 Mustang LX 2.3
could the new one be bad?? you should be able to get a reading from it.
what are you trying to see an o2 switching pattern with???
1991 Mustang LX 2.3L 5 Speed convert 1989 Ranger 4X4 2.3L 5 Speed Entire turbo kit waiting to be used again. |
and what is the code description for a 172??
1995 SVT Cobra
Very unlikely but as with any electronics, it's always possible. I'm pretty sure I'm reading off the right pins; the top two nearest to the press to release tab on the connector of the sensor.
1995 SVT Cobra
Fluke DMM, not sure of the model because it's not right in front of me but I think it's a 188.
1995 SVT Cobra
Oxygen sensor not switching/indicates lean condition.
Looking around, a failing fuel pump would make sense. I'm going to recheck the fuel pressure tomorrow to see how quickly it builds and how well it maintains pressure at 2000+rpm. I was only checking pressure at idle before and the code does not light the CEL at idle.
1995 SVT Cobra
The meter is actually a Fluke 87 series V DMM.
I thought i was reading from the correct oxygen sensor pins on the plug; the two top ones nearest to the push tab but that was giving me 0mV every time. I then checked the bottom two pins (which I thought were supposed to be the sensor heater) and got a varying voltage of 192 - 232mVdc. ------definitely a lean reading. I ordered a brand new 255LPH fuel pump today, hopefully this upgrade helps things.
#17 | |
Have you checked the intake for leaks?
#19 | |
1995 SVT Cobra
My Fluke meter has an input impedance of 10 Mohms and will show a varying voltage by activating the "max - min" mode.
1995 SVT Cobra
I don't have any high idle issues so I'm pretty sure I don't have an intake leak. The IAC was thoroughly cleaned and all intake-related gaskets were replaced.
Threads Similar to: Persistent check engine code 172
| Check engine light code | mystof | V6 Mustangs | 0 | October 9th, 2010 11:01 PM |
| Check engine code p171 | orangestang42 | 5.0 Mustangs | 24 | May 29th, 2010 02:16 AM |
| Check engine code help | hippojumqer | 99-04 | 0 | April 22nd, 2010 04:20 PM |
| check engine code 1151 | maverick0817 | 99-04 | 0 | October 24th, 2009 12:13 PM |
| Check engine light code | adam0421 | 2005 - 2010 | 2 | September 28th, 2008 12:05 PM |
