2.5 swap
has anyone ever tryied to put a 2.5l engine from a 99-01 ranger in a mustang? what all mods would need to be made? could u use the 5 speed from the ranger as well and just replace the gears in the tranny? i was also day dreaming about putting a 4.6 from a 03 gt in my car but i belive that would run a shit ton of money and alot of knowledge on whata to do. any thoughts on either of them
1991 mustang lx
i really dont know so much but i think the engine will fit with any problem, as i understand the block is the same with more bore and longer stroke crank , and the heads are the same, so its doable.
They are the same engine entirely, other than the stroke length. The swap would be seamless if you take a 2.5 bottom end and put a 2.3 head on it out of the car you have. I belive the 2.5 has round toothed cam drive set, so the pulleys from the 2.5 bottom end will need to be swapped to ones from a 2.3, or the 2.3 cam gear swapped for the 2.5 cam gear.
1991 Mustang LX 2.3L 5 Speed convert 1989 Ranger 4X4 2.3L 5 Speed Entire turbo kit waiting to be used again. |
so the 2.5 is a direct swap? how hard is it to swap the cam gears?
![]() 87 Notch Doing a lot with a little _____________________________ lightweight, stock motor, and 12's? |
yes it is a direct swap if you only swap the bottom end. the cam gear is easy to change. Make sure you time it correctly on reassembly.
How much power can the rods handle in a turbo app
1988 2.3L Hatch
Ha-Ha
You should be more worried about the cast pistons, unless you swap them for low comp forged.
Yes the stock pistons are no good for boost unless you go low low boost.
ok what about the computer can i still use my computer from my 93 2.3 or do i need to use one from a ranger? also can i use the tranny from the ranger also or do i need to stick with one from a mustang or thunderbird? if i can find a 2.3 tranny the belhouseing should work.
You should use the ecu for what engine the fuel injection system uses.
1988 2.3L Hatch
Ha-Ha
Use the Mustang trans in the Mustang with the 2.5L computer, injectors and MAF
Threads Similar to: 2.5 swap
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 04:33 PM |
| PI SWAP or ENGINE SWAP | JK7208 | 96-98 | 4 | March 19th, 2010 04:10 PM |
| pi swap or motor swap | whiteboy05 | 96-98 | 12 | December 8th, 2009 05:30 AM |
| PI Head Swap and Transmission Swap | jEEd | 96-98 | 18 | May 14th, 2009 12:57 AM |
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 06:48 PM |
