Small question about acceleration
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old April 4th, 2011, 05:12 PM   #1
2004 Mustang Convertible
Phinney is on a distinguished road
I am asking about my 1988 Thunderbird Turbocoupe. After my recent rebuild I have noticed a change in the throttle response (duh!) and I am a little confused. Before the rebuild, I had to floor it to WOT to really build boost. Now, I only open the throttle a hair, and no more, and it boosts right up to 15 or so and the car pulls hard.
Now, if I push the pedal and further, even halfway down, the car makes a hell of a lot of air noise like a bus and feels like its dragging and anchor, although it doesn't choke or sputter, just slower acceleration.
Because of this, its hard for me to drive this car without boosting through every gear. Ive checked the throttle and it opens properly, and the point where my car pulls the hardest is indeed just a small opening with the car off.
With my limited knowledge of turbo cars or performance engines in general, It makes me believe that with the throttle opened too much, its getting all that air, but not enough fuel. Im waiting for my exhaust to arrive in the mail, so my wide-band is not installed yet to confirm this. Also having a hard time finding the correct fitting to attach my fuel pressure gauge so I cant check on pressure either.
2004 Convertible - SOLD
1999 Coupe - SOLD
1966 Coupe - SOLD
1987 TurboCoupe - Cut in prices!
1970 Coupe - Soon to be 140 Turbo!
1984 El Camino Conquista - moving truck
2011 Convertible V6 Base
2012 Coupe GT Premium 5.0 Baby!
Old April 4th, 2011, 10:52 PM   #2
1991 Mustang 2.3L
11:42 @ 61 in the 1/8th
Mikel89us is on a distinguished road
Send a message via Yahoo to Mikel89us Send a message via Skype™ to Mikel89us
Im not sure if it would make that kind of difference, but have you double or triple checked your cam timing?
1991 Mustang LX 2.3L 5 Speed convert
1989 Ranger 4X4 2.3L 5 Speed
Entire turbo kit waiting to be used again.
Old April 5th, 2011, 02:45 PM   #3
Yeah cam timing is spot on
1999 Coupe - SOLD
1966 Coupe - SOLD
Old April 6th, 2011, 02:06 AM   #4
03 R Code's Avatar
unstoppable @ speed of light
03 R Code will become famous soon enough
Do you have an external wastegate or factory internal?
With the fuel pressure gauge just head down to ACE hardware. They are sure to have the fitting you need. I actually just spent $6 there 2 days ago to get the fittings needed for my new FPG. Found out the old gauge was not reading correctly and it was actually set at 60psi of fuel!!! That's a big problem for sure!
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Old April 6th, 2011, 08:21 AM   #5
still has the factory integral wastegate now. That sounds good, the last one i ordered off ebay and it was the wrong fitting, Ill try ACE today, thanks!
1999 Coupe - SOLD
1966 Coupe - SOLD
Old April 6th, 2011, 03:00 PM   #6
Dunno how I missed it before, but the clutch is slipping in a major way under boost. It still pulls harder than it ever did before. The clutch was brand new when rebuilt the engine, but it is just a stock replacement.
This is my first manual transmission. Any advice on what I need to do to upgrade the clutch? I just need to know what all parts I need to buy, the installation I can figure out.
The power is only going to continue to increase so I need to fix this quick like!
1999 Coupe - SOLD
1966 Coupe - SOLD
Old April 7th, 2011, 01:24 AM   #7
03 R Code's Avatar
Stinger sells SPEC clutches, each with a description of how much power it will hold if you need that. I've got a SPEC stage 2 on my car put on by the previous owner, although I'm not super high powered with my car, that clutch has held with 22psi of boost.
Threads Similar to: Small question about acceleration
Changing heads, have a small question. jivepepper 99-04 8 June 20th, 2008 05:19 PM
Acceleration HEMENWAY89GT 5.0 Mustangs 4 December 5th, 2007 07:39 AM
look wut came in the mail! small tech Question blown96stang V6 Mustangs 17 October 22nd, 2007 04:08 PM
small question about dropping idle flattusmaximus78 V6 Mustangs 4 July 15th, 2007 08:48 PM
question...small part on that big important expensive thing. flames_blue V6 Mustangs 8 January 31st, 2007 03:29 PM
