93 Stang running rough.
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old April 13th, 2011, 12:17 AM   #1
92 mustang gt
brianlepard28 is on a distinguished road
Send a message via Yahoo to brianlepard28
I believe I have a bad fuel injector but not sure. I have been running motorcraft platinum plugs and have been having some problems with it wanting to crank and what not. There is a hint of gas smell coming from the oil so I called a buddy he said take the platinum plugs out and put the reg ones back in. As I was changing plugs I noticed that one of the plugs looked kinda bad and the ceramic piece was cracked and broke in half. I replaced all the plugs and it's still acting up like it was before. Could the injector be bad or is there another problem? Also I'm leaking radiator fluid somewhere and not sure. I have no sign of fluid on ground and sometimes I have white smoke coming from tail pipe. Any thought?
Old April 13th, 2011, 09:45 AM   #2
1995 SVT Cobra
Cobraman1024 is on a distinguished road
Sounds like you should have a check engine light also. Do you? If you do you can short the diagnostic plug between the two pins in this picture, turn the ignition "on" but not start the car and watch the check engine light blink. This will get you started in terms of what codes are stored in the computer and give you a starting point on what to look at. Here is a link for that diagnostic plug:
FORD 1983-1995 OBD1 Decoder
If you think you have a bad fuel injector, unplug each one and check the electrical resistance. It should be between 14.8 and 15.1 ohms. If its wide open, infinite ohms or 0 ohms then its a bad injector. A 0 ohms injector would be stuck open all the time and could explain your gas smell in the oil----that cylinder with the open injector is flooded with fuel making the engine difficult to start and thus cranking for a long time until the extra fuel is dispersed.
The cracked ignition plug should have cleared up something of your cranking issue. I'm still using Autolite 764's but will be changing back to the Motorcraft AGSF32C plugs soon. Just for peace of mind that the Motorcraft plugs are the original ones for the engine. Your Platinum plugs; what part number is on the ceramic? Platinum plugs use a platinum tip at the end of a copper core so as long as they weren't manufactured by Bosch (which you said they were Motorcraft) then they should not have been a problem.
The "leaking" radiator fluid. oh boy, if you're losing coolant and its not leaking anywhere onto the ground or your passenger floorboard but you're having white smoke from the tailpipe----one thing pops in my mind immediately. A blown head gasket. That'll give you some issues with starting also. Do you have any coolant in your oil?-----oil will look like milk or coffee with creamer. Loss of engine power? Any overheating or the engine running warmer/hotter than normal? Normal is the coolant temp gauge reading between the 2nd and 3rd tick lines from the bottom.
1995 SVT Cobra #182/4005, 275/305, 217k miles
1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles
1995 Mustang, 3.8L, 233k miles
1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles
sold: 1987 GT
MM Military Crew Member
MM+Cleavage member #21
Old April 13th, 2011, 12:45 PM   #3
92 mustang gt
With the coolant issue there is none leaking on ground and yes I can't keep it from Overheating there is a loose of power and take off but after u get up and go it seems to run alittle better. All my issues are at ideal and take off that's it
Old April 13th, 2011, 12:47 PM   #4
1995 SVT Cobra
sounds like you'll need to get the head gasket replaced then. since its a four-cylinder engine, it wouldn't be all that difficult for you to do yourself with a Haynes manual and a little bit of experience working on engines.
sold: 1987 GT
Old April 13th, 2011, 07:50 PM   #5
92 mustang gt
As far as the fuel injectors go I have been looking at upgrading fuel injectors. ohc told me to get 30-36 pph I have been lookin but all I see is measured in lbs what would I need to look for lbs wise?
Old April 13th, 2011, 09:38 PM   #6
1995 SVT Cobra
I think by "pph" he actually meant pounds per hour. "lbs" is the abbreviation for pounds.
30-36 is way too large for a 2.3L four cylinder engine that is naturally aspirated. I just installed 19lbs injectors in my car but the perfect size is supposed to be 17lbs. The 17lb injectors can be found in GM 3.1L v6 engines as a common injector or in the Ford Focus Zetec engine of certain years.
The 19lb injectors are found most commonly in the 3.8L Ford engine in Thunderbirds and Mustangs. Plenty of those in junkyards.
sold: 1987 GT
Old April 13th, 2011, 10:40 PM   #7
92 mustang gt
im going with a stage 2 cam and some other high performance things thats why he yold me bigger injectors.
Old April 14th, 2011, 11:39 PM   #8
92 mustang gt
Cobraman I was looking at a post on here and saw a head from racer Walsh that come complete minus the cam. What else would I need to get for that head to be complete. I'm going to get forged flat top pistons and I believe the 1406 cam. Is there anything else I need to get to make it a complete rebuild or does that cover it all? Also getting a gasket kit too.
Old April 15th, 2011, 10:28 AM   #9
1995 SVT Cobra
If by complete, the seller means the head comes with intake and exhaust valves, springs and retainers then that would pretty much be it. You really need to find out what cam the springs are recommended to be used with. Also you'll probably need new head bolts in case the original Ford ones are torque-to-yield, i.e. one time use bolts.
You're going to need a tune also, as in a chip tune.
30-36lb injectors are still too large for your prospective combination lol..........People with turbos on these motors still only use 19 or 24lb injectors. 30-36 would be for an N/A 347 to 351ci engine at the minimum.
sold: 1987 GT
Threads Similar to: 93 Stang running rough.
car running rough bottled2v 99-04 13 March 18th, 2011 10:32 PM
Car running rough cbrown 99-04 5 February 1st, 2009 04:18 AM
My car is running rough 99BlackBetty 99-04 6 January 6th, 2009 01:49 PM
running really rough....help Traidmarx 5.0 Mustangs 4 December 23rd, 2008 11:22 AM
97 GT Running Rough? rainbowmustang 96-98 5 March 21st, 2007 04:00 PM
