93 2.3 turbo swap
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old April 26th, 2011, 07:35 PM   #1
00quicksilver is on a distinguished road
93 2.3 turbo swap
I know this topic has been beat to death but I want to ask some things specific to doing the turbo swap with the N/A motor. I have been pricing out some things and think I could do the swap between 1000-1500. Now, is it ok to use ebay turbo/intercooler or not? Also, if keeping MAF then should i use a universal and should it be blow-through or draw-through? Also, for swapping pistons into the N/A block, do I need to do anything other than a compression test? My N/A motor runs well but I don't know what to look for to make sure it can handle boost. Anyone have any experience trying to tune a MAF turbo setup? This is alot of questions I know, but I prefer to use the motor I have rather than buy a junkyard motor (they are going for around 600 around here with turbo too). Thanks all.
Old April 26th, 2011, 10:19 PM   #2
1991 Mustang 2.3L
11:42 @ 61 in the 1/8th
Mikel89us is on a distinguished road
Send a message via Yahoo to Mikel89us Send a message via Skype™ to Mikel89us
First off, dont buy an ebay turbo. The ebay Intercooler kit is ok, i got one and only had to make 2 cuts to make it fit.
Second, do not try to turbo a stock n/a bottom end. It will end badly. Go .030" over and buy low compression forged pistons.
Third, do NOT make the mistake i did and try to use a stock ECU without a tuner. It will not work. Your best bet is to buy a turbo coupe harness and ecu for starters. You can do it without but if you are just getting into it things will be very difficult to tune properly, and impossible without a tuner.
Your stock bottom end is all fine except the pistons. Your ECU is not fine for a turbo unless you buy a tuner. And if you get a turbo coupe ecu and harness you will also have to do a top-end swap and put in a distributor.
Your best bet is to find a complete turbo coupe engine and harness and rebuild the engine (rebuild the engine either way).
I hope this was helpful.
1991 Mustang LX 2.3L 5 Speed convert
1989 Ranger 4X4 2.3L 5 Speed
Entire turbo kit waiting to be used again.
Old April 27th, 2011, 03:42 AM   #3
03 R Code's Avatar
unstoppable @ speed of light
03 R Code will become famous soon enough
I've seen t/c motors go for $250 before on line. It would be cheaper to buy a junkyard 2.3T and find a harness/ecu/vam that fits it and go from there. With some searching you could have a motor/harness/ecu/vam for less than a grand. And at that point it's only really necessary to replace some gaskets in the engine unless it was known to have an issue before being scrapped.
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Old April 27th, 2011, 03:45 AM   #4
1991 Mustang 2.3L
Honestly, i would never put a used engine in one of my cars unless it has less than 40k miles on it. It never hurts to make sure your engine is perfect before putting it in the car.
Old April 30th, 2011, 12:00 PM   #5
92 mustang gt
brianlepard28 is on a distinguished road
Send a message via Yahoo to brianlepard28
I have a 93 n/a and looking at doing a turbo. I talked to a guy here and he is going to do it and when it's done he is going to dyno it and tune it. If u go mass air u have to put a bigger mass air on it.
Old April 30th, 2011, 11:31 PM   #6
I haven't responded back to this in awhile but I do plan on running a lighting MAF or something similiar (not too sure what to run, used to modulars). I don't like using a "used" engine either. Since I would have to have it torn down and rebuilt, I don't see why I wouldn't just use the one I have in my car. My major concerns are with the tuning aspect but I believe it can still be done. Hopefully I can learn enough through tuning to get it to run to a dyno. Let me know how the build goes brianlepard28. I want to shoot for 300rwhp or so in this build to run mid to low 12's at around 115 in the quarter. I could be way off but with the weight of our cars this should be possible at this power level.
Old May 1st, 2011, 07:39 PM   #7
1991 Mustang 2.3L
Well if you are going to have the one in your car rebuilt, all you should need is forged pistons, and an oil return machined into the block. Just to make sure that you know, you cant just slap a bigger MAf on it and go, you will have to buy a tuner.
Old May 2nd, 2011, 04:43 PM   #8
Yeah, for the power level I was going for I know I would need to have it tuned anyways. Can most normal machine shops put an oil return machined into the block?
Old May 2nd, 2011, 10:20 PM   #9
1991 Mustang 2.3L
Most can do the oil return, you could do it yourself with a drill and a pipe tap and the right fitting. And for higher HP than stock for a 2.3T yes you will need a tune.
Threads Similar to: 93 2.3 turbo swap
when doing a swap from 2.3 n/a to turbo 1989stang 2.3 Mustangs 1 October 29th, 2010 12:35 AM
2.3L turbo swap Ghosnj 2.3 Mustangs 1 July 29th, 2010 11:29 PM
V6 to 2.3 turbo swap? plak424 2.3 Mustangs 3 May 19th, 2010 03:32 PM
My turbo/T5 swap is nearly done BigBlockFairlane 2.3 Mustangs 9 September 23rd, 2009 10:46 AM
Turbo Swap 90ProjectStang 2.3 Mustangs 4 November 23rd, 2006 03:09 PM
