93 transmission into a 90
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old May 2nd, 2011, 07:25 PM   #1
1996 Mustang 3.8l
Walters97Racing is on a distinguished road
okay, so we have a job in our shop were doing for a friend. he doesnt have much money so hes doing this as cheap as possible. we have a 93' transmission. everything is fine except the 3 prong plug in the 93' transmission. the 90' transmission had a 2 prong plug. the plug is for the overdrive. what do we have to do to make this work?
96 v6 - needs v8
03 Roush - needs turbo
06 F250 6.0 - needs stepladder
Old May 2nd, 2011, 09:42 PM   #2
OHC230's Avatar
Supercharged 89'/ 85' SVO
11.945 @ 119.6
OHC230 is on a distinguished road
I think that swapping the 90' 3-4 shift solenoid into the 93’ transmission is the best way to remedy this problem. Hopefully the old solenoid is still good.
Supercharged 2.7L
398 HP
501 ft lb !!
Old May 2nd, 2011, 10:25 PM   #3
1991 Mustang LX 2.3
zonker is on a distinguished road
Upon looking at EEC diagrams, the 90's harness wires are red (VREF 5 volts) and Orange w/ yellow stripe (EEC #52 signal return).
If you look at the 3 terminals on the trans, they make a triangular pattern. Looking at the terminals, with the center terminal oriented as the topbof the triangle, that center terminal is the red VREF wire, and the CCO terminal #53 wire is to the right. I think you'd leave the terminal to the right un-connected.
that's my best guess anyways.
Rob
1987 Mustang 2.3 LX Convert (T5) project 2.5 N/A HP
1991 Mustang 2.3 LX Convert (A4LD)
1992 Mustang 2.3 LX Convert (A4LD) 41.52 mpg!!
1994 Capri XR2 1.6 Turbo Convert
1999 ZX2 S/R 2.0 Coupe
http://zxtuner.com
Threads Similar to: 93 transmission into a 90
Transmission redsnake 5.0 Mustangs 20 April 5th, 2010 08:48 PM
Transmission stevenm357 V6 Mustangs 3 March 28th, 2009 02:47 PM
Transmission ZoomZoomMFer 96-98 3 November 19th, 2007 05:53 PM
AOD transmission GT 5.0 5.0 Mustangs 11 September 24th, 2007 05:44 PM
Transmission flamed 98 gt 5.0 Mustangs 9 September 22nd, 2007 07:12 PM
