1993 mustang lx
19+seconds SLOW
5 lug conversion
will the 5 lug components off a 94 v6 mustang work on my 93. how hard would it be to do? will the axles work in the rear in the car now?
I dont know about the front end, but i am 99% sure that the 7.5 is an unchanged rearend. They used it from 79 to 2008 in any stang that wasnt a v8. (maybe longer?? but i doubt it the new v6 is a mean motor)
1991 Mustang LX 2.3L 5 Speed convert 1989 Ranger 4X4 2.3L 5 Speed Entire turbo kit waiting to be used again. |
1993 mustang lx
19+seconds SLOW
hopefully the front will work too. i wanna do the full swap. maybe even coverting to all 4 disk too
1988 2.3L Hatch
Ha-Ha
Axle shafts are longer for the rear disc brakes. Fronts you will have to change the knuckles also.
1995 SVT Cobra
I remember reading about there being some differences in the flare nuts for the brake hoses between the fox cars and the SN95 cars. You might want to check the threading and sizes between the two nuts.
There is a reason why Ford Racing sells fox-body specific front lower control arms and SN95 specific front lower control arms. I know that if you use SN95 spindles, you will have to use a spacer between the Fox balljoint and the SN95 spindle.
![]() 1995 SVT Cobra #182/4005, 275/305, 217k miles 1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles 1995 Mustang, 3.8L, 233k miles 1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles sold: 1987 GT MM Military Crew Member MM+Cleavage member #21
1993 mustang lx
19+seconds SLOW
thanks i didnt know that. im thinking of sticking to 4 lug now and just coverting to rear disk. more on my budget
1988 2.3L Hatch
Ha-Ha
You can do it on the cheap with Ranger 4 cyl front rotors and 2 driver side Aerostar axles( or was it Pass side)
you can use ranger axles
1988 2.3L Hatch
Ha-Ha
Driver side Ranger and passenger side Aerostar axles are the same
Threads Similar to: 5 lug conversion
| 65 T-5 Conversion | Wyld Stang | Classic Mustangs | 11 | May 8th, 2010 09:09 PM |
| SD to Maf Conversion on 94 E-150 van 5.8l | Tyler2009 | 5.0 Mustangs | 5 | February 18th, 2010 04:29 PM |
| Conversion? | Feliberty | 2.3 Mustangs | 13 | September 3rd, 2008 03:37 AM |
| T5 to C4 Conversion | 89LX347 | 5.0 Mustangs | 2 | December 2nd, 2007 11:39 AM |
| MAF conversion | Drick | 5.0 Mustangs | 27 | November 6th, 2007 12:46 PM |
