600 miles from ONE tank of gas?! - Page 2
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
LinkBack (4) Thread Tools
Old May 18th, 2011, 03:51 AM   #21
1991 Mustang LX 2.3
zonker is on a distinguished road
Originally Posted by NFChaos2003 View Post
Questions/Comments on certain mods
1. Is the intake a CAI type setup or stock?
2. Most cars like either copper or Iridium Plugs, most don't like platinum but, then again I don't know 2.3s, feel free to correct me.
3. You should do a custom header-back exhaust with a Spun high flow cat and straight through muffler instead, it'll give you some more power and MPG.
4. I don't know what rims you are using but, you could get some knock-off lightweight rims for cheap with the low-resistance tires they make for hybrids now.
5. You could try and modify an aluminum driveshaft to work for your car to decrease rotational weight.
1. intake uses the stock airbox and it is a partial cold air, meaning it pulls in air from the stock cold air inlet by the radiator and air from under the hood thru the hot air tube entrance. purely cold air is not preferred when fuel economy is the goal.
2. without getting too lengthy here about spark plugs, let me just say that the copper refers to the center core of some plugs and is considered a good material for offering low resistance transfer of spark to the firing tip.
platinum or iridium refers to the material surface of the electrode. iridium electrodes is a harder material than platinum, which is a harder material than the standard steel electrode. the benefit of harder firing tip metals means you can reduce long term wear by making it harder for the material to erode. it also allows you the ability to shrink the diameter of the firing tip and electrode, which provides a more accurate, controlled spark.
the avoiding platinum plugs syndrome/myth comes from is that the harder plats operate at a higher firing tip temp. this is a plus for a economy motor, but can cause pre-ignition issues in a nitrous or boosted application, so thats where the plats get the bad rap. colder heat ranges can help offset this problem however.
3. working on a plan for the best exhaust - it's going to be tough to craft something that will actually pass Cali smog checks though since nothing aftermarket is CARB appproved for the 2.3 mustang. the trick will be keeping the back pressure down and the low rpm flow velocity high.
4. got the rim/tire thing in the works too... either beetle tires on alloy cobra spare rims or wheel adapters and hollow spoke miata alloys with hybrid LRR tires.
5. i like the driveshaft idea, but i don't think it will provide any gain worthy of the cost of making one so i'll pass on that one.
Rob
1987 Mustang 2.3 LX Convert (T5) project 2.5 N/A HP
1991 Mustang 2.3 LX Convert (A4LD)
1992 Mustang 2.3 LX Convert (A4LD) 41.52 mpg!!
1994 Capri XR2 1.6 Turbo Convert
1999 ZX2 S/R 2.0 Coupe
http://zxtuner.com
Old May 19th, 2011, 08:37 PM   #22
1993 2.3 LX Convertible
96flmustang is on a distinguished road
Zonker, too bad you didn't quite make it. But I'm sure you will make some adjustments and soon hit your goal. I imagine you would hit your goal if you weren't going up long hills. Now I am inspired to do the same to my 2.3 and see what I can do. I'm currently at 17 mpg average on a tank of gas. This has to change.
Old May 20th, 2011, 12:02 AM   #23
1991 Mustang 2.3L
11:42 @ 61 in the 1/8th
Mikel89us is on a distinguished road
Send a message via Yahoo to Mikel89us Send a message via Skype™ to Mikel89us
17 is the kind of milage you should get out of a turbo car xD i get about 24 and im usually not gentle on my car.
1991 Mustang LX 2.3L 5 Speed convert
1989 Ranger 4X4 2.3L 5 Speed
Entire turbo kit waiting to be used again.
Old May 20th, 2011, 09:39 AM   #24
jjpluml's Avatar
1987 5.0 HO, 1984 SVO
jjpluml is on a distinguished road
my lx is gettin about 26-28 right now and it is bone stock. stock exhaust, intake, everything
92' lx 2.3 bone stock dd trunk car
84 SVO with a few bolt ons
87 gt project with a whole bunch of shit thrown at it and a lil juice...
Old May 20th, 2011, 12:35 PM   #25
1991 Mustang LX 2.3
a stock 91-93 mustang has a epa rating of 19 city / 26 hwy (current epa calcs).
Rob
http://zxtuner.com
Old May 21st, 2011, 09:00 AM   #26
jjpluml's Avatar
all i use it for is back and forth to work and the speed limit from my house to there is ab 50. does pretty well at that speed.
Old May 28th, 2011, 01:23 AM   #27
1991 Mustang LX 2.3
ideal fuel economy speed is 1600-1900 rpm in top gear, and 50 mph fits that bill.
Rob
http://zxtuner.com
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2-3-mustangs/217787-600-miles-one-tank-gas.html
For Will, mustang mpg This thread Refback May 17th, 2011 05:25 PM
For Will, mustang mpg This thread Refback May 17th, 2011 03:14 PM
For Will, mustang mpg This thread Refback May 17th, 2011 10:05 AM
For Will, mustang mpg This thread Refback May 17th, 2011 10:02 AM
Threads Similar to: 600 miles from ONE tank of gas?!
How many miles have you gone on a tank of Gas in your Stang? ga289stocker 99-04 78 May 21st, 2011 10:46 AM
miles to your tank? LoveStangs88 96-98 15 September 2nd, 2010 07:06 PM
post your highest and lowest miles per TANK Imran 99-04 28 June 16th, 2009 04:23 AM
25 Miles On A Quarter Of A Tank Dansby The Clubhouse 24 December 7th, 2007 12:21 AM
miles per tank Drick 5.0 Mustangs 23 July 28th, 2007 07:54 PM
