sway bar size.
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old May 18th, 2011, 08:55 PM   #1
skippy84's Avatar
1993 mustang 4cl
n/a
skippy84 is on a distinguished road
sway bar size.
ok well i have a 93 mustang lx 2.3l with a 15/16 front sway bar. i know that some cars came with bigger ones. does anyone have experience with the diferenses in the size and feel of the front bars? thanks . and out of what cars/ and years can i get the rear sway bar out of? mine did not come with one in the rear.
Old May 18th, 2011, 11:16 PM   #2
1991 Mustang LX 2.3
zonker is on a distinguished road
any of the v8 mustang bars will fit on your 2.3, both front and rear.
before you start adding a fatter front bar, lets try to figure out what your car truly needs to corner flatter and more neutral.
check your tires for correct air pressure, empty all the stuff in your car that does not belong there, and go drive the car hard on your favorite road (large parking lots or abandoned airports are preferred in case yu take a corner too hard).
now, when you take the corners hard, which tires tend to lose traction first, the fronts or the rear?
if it's the rear, add a fatter front bar
if it's the front, add a rear bar
Rob
1987 Mustang 2.3 LX Convert (T5) project 2.5 N/A HP
1991 Mustang 2.3 LX Convert (A4LD)
1992 Mustang 2.3 LX Convert (A4LD) 41.52 mpg!!
1994 Capri XR2 1.6 Turbo Convert
1999 ZX2 S/R 2.0 Coupe
http://zxtuner.com
Old May 18th, 2011, 11:21 PM   #3
skippy84's Avatar
1993 mustang 4cl
n/a
thanks. great advice. i will do that tonight.
Old May 20th, 2011, 01:29 PM   #4
ocejo's Avatar
92 LX 2.3N/A
ocejo is on a distinguished road
I just removed one from my 85 gt before taking it to the scrapper, it is bigger that on my 92 2.3. I will also be installing the rear one off a 95 3.8
Threads Similar to: sway bar size.
To Sway or Not to Sway: That is the question! 2010konagt 2005 - 2010 4 November 29th, 2010 08:56 PM
2009? 2010? .... [SIZE="2"]camaro?[/SIZE] ????? Any updates?? r00st 2005 - 2010 10 August 2nd, 2008 01:19 AM
What is teh stock sway bar size on a 2001 mustang gt ? RanGer498 99-04 3 March 2nd, 2008 10:11 AM
Sway Bar soccerboy08 V6 Mustangs 10 January 29th, 2008 05:25 PM
sway bar size 1gunner23 5.0 Mustangs 5 March 25th, 2007 04:10 AM
