1993 2.3 LX Convertible
Headlight flickers
My headlights start to flicker when I put the car in drive. When its in park the lights are fine. I am not sure what would be causing this. Alternator? Bad light switch? But if a bad switch, wouldn't it always flicker even if in park?
1991 Mustang LX 2.3
when you say flicker, fo you mean dim/bright, or do you mean on/off?
the way to see if it's charging system is to watch your volt gauge while the lights are flickering. if the needle moves to discahrge the same time your lights get dim, then it indicates a charging system or bad wiring condition. if the lights come on and off, then i'd look at the bulb itself and the headlight switch, then the wiring - in that order.
Rob 1987 Mustang 2.3 LX Convert (T5) project 2.5 N/A HP 1991 Mustang 2.3 LX Convert (A4LD) 1992 Mustang 2.3 LX Convert (A4LD) 41.52 mpg!! 1994 Capri XR2 1.6 Turbo Convert 1999 ZX2 S/R 2.0 Coupe http://zxtuner.com
The lights look as if if have gone over some bumps but I haven't. Its a steady flicker. The meter gauge on my car always moves up and down fast. I def think the gauge is loose so its hard to tell by looking at the gauge. The lights don't actually shut all the way off. Just get a little less bright and then back to normal. Tough to explain.
Threads Similar to: Headlight flickers
| take out right headlight? | 02gtmustang | 99-04 | 30 | July 20th, 2009 10:36 PM |
| Headlight Help | weems | 99-04 | 2 | July 18th, 2009 04:35 PM |
| headlight | vdubsnstangz | 99-04 | 1 | April 4th, 2009 07:56 PM |
| headlight help please | 03TropicGt | 99-04 | 5 | July 27th, 2008 05:30 PM |
| Which headlight looks better | chromestang01 | Visual | 8 | June 14th, 2008 09:11 PM |
