2.3l t-5 swap from automatic trans
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old May 23rd, 2011, 09:54 PM   #1
1988 mustang lx soft top
fredstar is on a distinguished road
hey everyone,
ive been working on a prodject for a long time, finally done enough research to get it going.
let me give you a run down, i have bought a motor and trans, (attached to eachother) its out of a 86, i have a 5.0 carbureted motor, with a t-5 bw trans, im curently working right now, so i need to get it up and running at least, so i was thinking of just swaping the trans in for now, but i have some concerns, like can i use all the parts like, flywheel, clutch, bell housing, everything that came with the motor and tranny i bought to fit it on the 2.3?
in planner simpler words, since i have the motor and tranny, and only want to swap one at a time, will i need to buy any adapter plates or anything to make it work?
Old May 23rd, 2011, 11:17 PM   #2
1991 Mustang 2.3L
11:42 @ 61 in the 1/8th
Mikel89us is on a distinguished road
Send a message via Yahoo to Mikel89us Send a message via Skype™ to Mikel89us
Buy a 4 cyl clutch flywheel and bell housing. The hardest part of the entire swap is installing the clutch pedal. The best plan for that is to get a setup out of a manual car and swap the assembly. Its a pretty strait forward job if you have the parts.
1991 Mustang LX 2.3L 5 Speed convert
1989 Ranger 4X4 2.3L 5 Speed
Entire turbo kit waiting to be used again.
Old May 24th, 2011, 04:46 PM   #3
i got the clutch pedal done, what i want to know is, can i just swap everything over from the 5.0, to the 2.3 in terms of installing the t/5 trans? or i need a 4cyl clutch and flywheel and bell housing, in order to make the t-5 work? not completly understanding, i know its how i word it.
Old May 24th, 2011, 11:39 PM   #4
1991 Mustang 2.3L
You will need to buy the clutch flywheel and bell housing. They will not fit from a 5.0 to a 2.3l. Thats why i said buy the parts. Sorry if i confused yo much.
Old May 29th, 2011, 08:43 AM   #5
1995 SVT Cobra
Cobraman1024 is on a distinguished road
One other note. The bellhousing and starter plate are specific for the 1990 and earlier cars because of the oil pan. I have a bellhousing and starter plate that will fit your car and the bolts for them too. Send me a PM if your interested in them for a reasonable price. I think I also have a spare clutch fork but you will need to find the two cables. There is a short cable that connects to the bellhousing linkage and a long cable which connects to the clutch pedal.
1995 SVT Cobra #182/4005, 275/305, 217k miles
1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles
1995 Mustang, 3.8L, 233k miles
1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles
sold: 1987 GT
MM Military Crew Member
MM+Cleavage member #21
Old May 30th, 2011, 01:37 AM   #6
Cgross609's Avatar
93 Mustang LX 2.3 T-5
Cgross609 is on a distinguished road
So will an 89 2.3 bellhousing work on a 93 2.3? Before i go and spend 140 some odd dollars on a clutch kit and flywheel?
93 2.3l LX
U.S. 15x7 ten hole rims
Calypso green
Moates QH
T-5 Conversion
Dual 2.5" Exhaust with Thrush Welded muffler
Old May 31st, 2011, 07:52 PM   #7
ocejo's Avatar
92 LX 2.3N/A
ocejo is on a distinguished road
cobraman pm me on the parts you have available.
Threads Similar to: 2.3l t-5 swap from automatic trans
intercooler automatic trans MustangMan00Vtech 99-04 6 May 21st, 2011 03:50 AM
Automatic trans question 91convlx 5.0 Mustangs 4 January 25th, 2011 01:44 AM
99 V6 Automatic Trans Slipping After 2nd myblackstallion V6 Mustangs 3 April 25th, 2010 05:35 PM
Automatic trans Drag TotoGT06 Drag 19 March 16th, 2009 12:55 PM
Automatic Trans wveil3v 2005 - 2010 4 February 22nd, 2009 04:49 PM
