1987 5.0 HO, 1984 SVO
takin SVO to track sat....
takin my 84 svo to a 1000ft track this weekend and i was wondering if you guys had any helpful tips, and any last minute adjustments or things i should do to the car before i go. Car has 3" turbo back, cold air, boost controller, fmu, and thats pretty much it...
92' lx 2.3 bone stock dd trunk car 84 SVO with a few bolt ons 87 gt project with a whole bunch of shit thrown at it and a lil juice... |
practice launches
Make sure you have good rear tires.
1991 Mustang LX 2.3L 5 Speed convert 1989 Ranger 4X4 2.3L 5 Speed Entire turbo kit waiting to be used again. |
im going to go out the next few nights and practice a little. what do u think is the best launch technique with the turbo 2.3? and ive got good tires on it that are a street tire but arent to hard and im going to be running them pretty low psi... just didnt know if there was anything that you guys recommended to check or do to the car before i took it down... im new to the whole drag racing thing ive always been a road course guy
just make sure you build boost before that light turns green. Find where your car likes the RPM at for that.
right on i appreciate it
unstoppable @ speed of light
Unless you have a 2 step or something similar I don't know any way to build boost with an otherwise factory SVO.
The 2.3T will run better with some wheel spin than bogging down. I would start at 4k rpm launch and judge how much spin you get, if it's a lot and no bog at all then drop a little, say 3500 rpm, if it bogs then go back up. You can also take off the front sway bar for some better weight transfer. I wouldn't go very low on tire pressure with a street tire. It could "cup" in the contact patch effectively removing a lot of traction. The harder sidewalls and rubber do that. Take out whatever weight you can. What is your boost set at and how much fuel pressure does it show?
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end. |
im going to be running ab 22psi and im running a fmu. i dont have an actual fuel pressure guage but i am running a a/f meter and im running rich pretty much alll the time
What part of AR are you from?
fayetteville. Were goin down to centerville which is close to russellville if you know where that is...
oh and i was messin with the car last night doin a few thing like changin oil etc and i turned the boost controller up more just to see what it would top out at. The guage is reading 27psi in all gears. i didnt think a stock turbo would flow that much?? im going to turn it back down anyway im afraid to run it that high. Im also thinking about running a 50 shot dry... what do u think if im running 22-25 psi and the nitrous? bad idea?
48.47@ 12.58
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 10 reviews
27psi on a t-3? Is your waste gate stuck closed? lol
i dont friggin have a clue lol i was kinda wondering the same thing... and i was wondering if maybe my guage was off so i swapped to another one that i had layin around and it read the exact same....
The t3 will make that boost but it's more heat than anything else. They are really pretty useless past 23psi. With your fuel set up I wouldn't run past 19psi, and even that you should be listening really close for detonation.
What did your a/f gauge say when you were at 27psi? Nitrous would be a bad idea for how you are set up right now. Especially with a dry shot you are essentially adding more air to what is already a lot of air when in boost. Very doubtful the factory injectors will flow enough to handle that and you will likely burn a hole in a piston. Same story with running up to 27psi in all gears. That's a very dangerous thing to play with. I'm from Genoa, AR. About half an hour outside of Texarkana. I've got family that live in Rodgers. Did you make it out to the track? I hope you decided against that nitrous and 22-25psi...
Actually after rereading your set up, there is no way factory 84 fuel pumps will supply enough fuel for that much boost, let alone nitrous on top of it.
yea man i made it out and i didnt run the nitrous. She did run fine at 23 psi though. I ended up runnin some pretty decent times and had a blast. U ever been down to centerville? Rogers is ab a 10 min drive from where i live lol
Nope, never been to Centerville, and only been to Rodgers and Eureka Springs once.
What were your times? You gotta share!
1991 mustang lx
I dont know if removing parts from the car its legal in the US drag races, if not, take out your hood and everything that can give weight to the car =)
Threads Similar to: takin SVO to track sat....
| im takin the chicken out yo car | graystang01 | The Clubhouse | 8 | July 13th, 2010 11:18 PM |
| Takin it to the hole! | ~C~ | The Clubhouse | 4 | August 5th, 2008 11:50 AM |
| takin off my headers | shiftyV6 | V6 Mustangs | 3 | December 27th, 2007 09:10 PM |
| takin a shit | WilltheThrill | The Clubhouse | 17 | October 29th, 2007 04:15 PM |
| takin a break from MM | BWAL | The Clubhouse | 40 | July 13th, 2007 08:21 PM |
