92 LX 2.3N/A
92 tach
now that I've got my car back on the road, I will be checking the smaller issues. For now I need to figure why the tachometer reads rpms incorrectly. I just it smogged today and noticed that it is not close at all to where they really are. is there a tach wire to the coils like the single coil cars?
1991 Mustang LX 2.3
the tach gets its signal from the DIS module at terminal #12 (tan w/ yellow stripe). That wire is connected to the EEC, the tach, the DIS module, and the tach service connector behind the drivers side strut tower.
Rob 1987 Mustang 2.3 LX Convert (T5) project 2.5 N/A HP 1991 Mustang 2.3 LX Convert (A4LD) 1992 Mustang 2.3 LX Convert (A4LD) 41.52 mpg!! 1994 Capri XR2 1.6 Turbo Convert 1999 ZX2 S/R 2.0 Coupe http://zxtuner.com
92 LX 2.3N/A
so how would I repair a faulty tach? replace cluster?
He cant tell you what is wrong. You need to test the circuit and see if you find a problem.
1991 Mustang LX 2.3L 5 Speed convert 1989 Ranger 4X4 2.3L 5 Speed Entire turbo kit waiting to be used again. |
1991 Mustang LX 2.3
it's always nice to have a spare set of parts floating around to confirm or deny the fault, so you can swap one part with another to see if problems go away or persist...
i know in times of hair pulling on electrical conditions I like to remove a working part from one of my mustangs and try it out on another. i just did exactly that with my '92, when I had a no-start condition. I suspected the starter relay because it was old, unlike the starter i just installed, and if i bypassed the ignition switch/ neutral switch wiring by arcing the relay terminals, it would do the same thing. so i tried the working relay on my '91 and i still had a no start. further, i installed the 92's relay on the '91 and the '91 was starting fine. the problem - a loose crimp on the butt connector connecting the new starter's solenoid wirirng and the car's harness. I crimped the shit out of the butt connector and all is good. the moral of the story: skill is good but parts are better (unless you have to pay for the privilege). and on that note - pick your parts in Chula Vista is having a half price sale today and tomorrow, or I can sell you a working unit I have from a previous cluster swap.
92 LX 2.3N/A
ok I'll see if I can try a spare cluster if not you're looking at a future sale..
Threads Similar to: 92 tach
| Tach wire for Tach adapter? | Matt. | V6 Mustangs | 2 | April 24th, 2011 01:34 PM |
| tach install..... tach adapter | 02S281 | 99-04 | 8 | August 21st, 2008 01:35 PM |
| Autometer Tach/Tach Light and Ford racing Tach Driver install help | 94stang | 99-04 | 10 | April 18th, 2008 11:35 PM |
| Tach help | BoostHard1210 | 99-04 | 2 | July 30th, 2007 01:31 PM |
| A tach ???????? | lugthug713 | 5.0 Mustangs | 4 | December 25th, 2006 02:49 AM |
