91-up 2.3's have no oil pressure gauge!
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
LinkBack (1) Thread Tools
Old May 28th, 2011, 01:01 AM   1 links from elsewhere to this Post. Click to view. #1
1991 Mustang LX 2.3
zonker is on a distinguished road
Yep, thats right... even though theres a gauge on the instrument panel, and it does go from zero to half way once the motor is running, it's still not a gauge.
It turns out the 2.3 does not use a variable resistance oil pressure sending unit, but rather a simple on-off oil pressure switch blended with a 20 ohm resistor to give the impression that the gauge is giving you some sort of pressure reading other than zero.
The 5.0's use a real oil pressure sending unit and do not have the resistor added to the gauge, so they show true oil pressure based on variable resistance of the sending unit.
So... if you want your gauge to truly work, a 5.0 sender and removal of the resistor on the gauge will be in order.
Rob
1987 Mustang 2.3 LX Convert (T5) project 2.5 N/A HP
1991 Mustang 2.3 LX Convert (A4LD)
1992 Mustang 2.3 LX Convert (A4LD) 41.52 mpg!!
1994 Capri XR2 1.6 Turbo Convert
1999 ZX2 S/R 2.0 Coupe
http://zxtuner.com
Old May 28th, 2011, 01:13 AM   #2
1991 mustang lx
BrianF is on a distinguished road
are you sure about that? o0
Old May 28th, 2011, 01:14 AM   #3
1991 Mustang LX 2.3
yep - just read it in my factory EVTM - with schematics to boot.
Rob
http://zxtuner.com
Old May 29th, 2011, 06:08 AM   #4
1991 Mustang 2.3L
11:42 @ 61 in the 1/8th
Mikel89us is on a distinguished road
Send a message via Yahoo to Mikel89us Send a message via Skype™ to Mikel89us
good info! I figred that was the case anyway, because my OP gauge always reead the same. cold of warm.
1991 Mustang LX 2.3L 5 Speed convert
1989 Ranger 4X4 2.3L 5 Speed
Entire turbo kit waiting to be used again.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2-3-mustangs/220304-91-up-2-3s-have-no-oil-pressure-gauge.html
Low oil pressure at cruise and accel. - Ford Mustang Forums This thread Refback September 8th, 2011 07:46 PM
Threads Similar to: 91-up 2.3's have no oil pressure gauge!
Oil Pressure Gauge rdspins89 2005 - 2010 1 February 23rd, 2011 12:45 PM
Oil pressure gauge ? centipede3001 5.0 Mustangs 6 December 9th, 2010 02:36 PM
Oil pressure gauge RC02GT 99-04 17 March 22nd, 2009 12:09 AM
Oil Pressure gauge Novanutcase 99-04 11 January 21st, 2009 09:54 PM
