2.3 problems - Page 2
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old May 17th, 2007, 01:07 AM   #21
ks_emt is on a distinguished road
Send a message via AIM to ks_emt Send a message via MSN to ks_emt Send a message via Yahoo to ks_emt
EEC? wouldnt the car not start if it was fried?
Old May 17th, 2007, 06:39 AM   #22
TurboLX's Avatar
1988 Mustang LX Turbo
it would still start
Old May 17th, 2007, 01:34 PM   #23
so that being bad would lean my fuel out to nothing at top end and therefore have no more power .
Old May 17th, 2007, 03:06 PM   #24
TurboLX's Avatar
yep pretty much so everything runs on its own
Old May 17th, 2007, 10:58 PM   #25
well i found out that the car has sat for about 2 years. so i needs a really good cleaning and changing the cats. ill do that and see if that helps.
Old May 17th, 2007, 11:30 PM   #26
Old May 18th, 2007, 07:37 AM   #27
TurboLX's Avatar
oh man, shes one hurting hatch back, but that engine looks UN-touched so it has to be the EEC
Old May 18th, 2007, 11:53 AM   #28
well under acceleration it cuts out a little bit i dont know if its because it has set for such a while or what.
Old May 18th, 2007, 03:44 PM   #29
well after seeing all you can do with a 2.3 turbo i just might have to go that route and keep my gas mileage.
Old May 18th, 2007, 04:00 PM   #30
TurboLX's Avatar
i'd say mod the 2.3 thats in it now and find a 2.3T E3 block and build it up
Old May 18th, 2007, 04:13 PM   #31
so a CAI and header and exhaust should pick it up a lil bit. and where is the EEC located and how do i know its bad?
Old May 18th, 2007, 06:25 PM   #32
MSO
MSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the rough
Send a message via AIM to MSO
im not sure if this is wut ur talking about, but ur car has a knock sensor on it
at the slightest sign of knock, it kicks ur engine timing back like 10 degrees
and it takes a couple minutes to go back to normal.. try taking that off and see if it helps
not sure tho , it might jus be ur EEC, but u still wanna take off the sensor cuz it does do that
[SIGPIC][/SIGPIC]
Old May 18th, 2007, 06:34 PM   #33
TurboLX's Avatar
no it sounds like the EEC is shot but its starting to sound like the timing is set retarted, and the EEC located in the passenger kick panel, and yes and intake will do more for you,
Old May 21st, 2007, 01:53 AM   #34
well i can stomp the gas to the floor and the rpms go upslowly so that might be timing noticing the cap and wires were just replaced.
Old May 21st, 2007, 07:12 AM   #35
TurboLX's Avatar
get a timing light and check for a notch on both the cam and the crank and see where there at
Old June 27th, 2007, 01:32 PM   #36
well it will go 70 mph but it seems like a throttle problem i can stomp the gas to the floor and it acts like it wants to die. also can an automatic eec work with a manual tranny?
Old June 27th, 2007, 01:46 PM   #37
TurboLX's Avatar
it def. sounds like a timing issue, im not sure about the EEC ither, let me look
Threads Similar to: 2.3 problems
2.3L Problems. akatagyourit 2.3 Mustangs 51 June 25th, 2007 03:39 PM
more problems ks_emt 2.3 Mustangs 7 June 7th, 2007 03:16 PM
EEC IV problems tekt 5.0 Mustangs 3 February 19th, 2007 01:00 AM
88 GT With A Few Problems Iceman1989 General Tech 3 November 14th, 2006 12:58 AM
Help Please (Car Problems) 98mustang98 V6 Mustangs 1 October 25th, 2006 10:49 PM
