1988 Mustang vert 2.3L
cold air intake ideas
so in the experiment process,im trying to figure out the best custom cold air setup for my car.. earlier plans were to run 3" mandrel bent pipe through the inner fender and run the filter all the way up to an opening on the front bumper cover... now im wondering if i can get the same performance by running the piping where the stock air box was and build a enclosure around the filter where the only opening would be by the hole in the firewall.. anyone try this?
As ohc230 had told me, that the stock box is good enough with little to mods. I only cut a 3" exhaust piping and wrapped it with thermo header wrap. Zonker said that i didn't have to go that big but it was made already and seems to work. Gains, more power for highway on ramps and mpg.
1995 SVT Cobra
The only thing I've done for my induction system is remove the restrictor in the fat tube and also removed the flap from the airbox.
![]() 1995 SVT Cobra #182/4005, 275/305, 217k miles 1996 SVT Mystic Cobra #1666/2000, 267/263, 178k miles 1995 Mustang, 3.8L, 233k miles 1993 Mustang LX, 2.3L, T5 convert, 95 GT suspension swap, 03 Cobra steering rack, 250k miles sold: 1987 GT MM Military Crew Member MM+Cleavage member #21
well im trying to figure out some kind of diagram in the bay on how i should route it..might make some test pieces from scrap and get some results.. i have a short ram on it now i got off of ebay and the filter points it the direction of the radiator.. its probably still getting warmer air through it..
1989 mustang lx
I used bbk's 1557 cold air intake. I had to make my own piece so it would hook up to the throttle body. But it works pretty good.
BBK: 1986-1993 Ford Mustang 5.0L Cold Air Intake System - BBK |
If you are set on using an aftermarket filter setup, building the enclosure would be a good idea, but you should make a tube that comes from the front somewhere.
1991 Mustang LX 2.3L 5 Speed convert 1989 Ranger 4X4 2.3L 5 Speed Entire turbo kit waiting to be used again. |
yeah im pretty set on using an aftermarket set up... ill sketch some ideas up either tonight or tomorrow...
1988 2.3L Hatch
Ha-Ha
I saw a home made Lightning airbox made from a plastic trash can once. I will see if I can find it again.
http://www.f150online.com/forums/lig...ir-intake.html |
LMFAO... Thats the shit!! i never thought about that one... ill keep that in mind for mine...plus it wont rob me alot either... thanks michigan stanger!!
Threads Similar to: cold air intake ideas
| 01 3.8 short ram air intake or cold air intake? | dgrazak | V6 Mustangs | 13 | May 18th, 2010 10:16 PM |
| Stock Air intake-Cold air intake | Steelsoldi3r | 96-98 | 24 | January 22nd, 2010 01:22 AM |
| Where can i buy a Cold Air intake? | Kriz818 | 2.3 Mustangs | 3 | January 31st, 2009 11:23 AM |
| short ram intake or cold air intake????? j/w | Stangbro8994 | V6 Mustangs | 32 | September 18th, 2008 08:20 PM |
