What ECU do i have?
Go Back   Forums at Modded Mustangs > Mustang Forums > 2.3 Mustangs
Old October 3rd, 2011, 10:32 PM   #1
1991 Mustang 2.3L
11:42 @ 61 in the 1/8th
Mikel89us is on a distinguished road
Send a message via Yahoo to Mikel89us Send a message via Skype™ to Mikel89us
What ECU do i have?
I recently picked up at T-Bird ECU and harness, its from an 87 Turbo coupe, and i was wondering what it is. Im not sure how to figure out if its LA or LB or what number. It was an automatic trans car.
1991 Mustang LX 2.3L 5 Speed convert
1989 Ranger 4X4 2.3L 5 Speed
Entire turbo kit waiting to be used again.
Old October 7th, 2011, 08:09 AM   #2
OHC230's Avatar
Supercharged 89'/ 85' SVO
11.945 @ 119.6
OHC230 is on a distinguished road
It should have a sticker on it, near the plug, if not re-post.
Supercharged 2.7L
398 HP
501 ft lb !!
Old October 7th, 2011, 11:30 PM   #3
1991 Mustang 2.3L
it does, and it has what looks like a blue stamp that says LB13 or something like that
Old October 8th, 2011, 07:28 AM   #4
OHC230's Avatar
11.945 @ 119.6
OK, so it's an LB1, which is fine for a turbo application. What are you planning to do with it?
Supercharged 2.7L
398 HP
501 ft lb !!
Old October 8th, 2011, 09:06 AM   #5
1991 Mustang 2.3L
turbo on my mustang. What would be a safe compression ratio to run 6 psi?
Old October 9th, 2011, 12:55 PM   #6
OHC230's Avatar
11.945 @ 119.6
9.0:1 at 6 PSI with an intercooler should be OK for a cast piston, but I would suggest you run 91 or higher octane fuel if this is your plan.
If you are going to use forged pistons, you could get away with 10.5:1. I'm guessing that you are looking for more low speed torque in this engine, hence the high compression/low boost combo? If this is what you are after, then I suggest that you use the stock valve sizes in the head and PM me for some porting tips. What cam are you planning on using for this?
Supercharged 2.7L
398 HP
501 ft lb !!
Old October 9th, 2011, 09:40 PM   #7
1991 Mustang 2.3L
I have hyperutectics and about 10.3 to 1 right now
Old October 9th, 2011, 09:44 PM   #8
1991 Mustang 2.3L
And yes im going for low speed torque, i have the stock cam in it, dont think i will change it right now. I have an external wastegate that is set at 6 psi anyway so i decided to keep high compression, due to the failure at power before with 6 psi
Old October 9th, 2011, 09:45 PM   #9
1991 Mustang 2.3L
and i do have an intercooler too, front mount
