1988 Mustang vert 2.3L
instrument cluster problems...
lately on my 88 vert some of my guages are messed up.. first of all the oil pressure guage twitches now and then and im assuming the sending unit is acting up... the other is the speedo.. when im on the highway doing 55-60 mph it bobs up and down.. do i need to change the whole panel? i heard and saw that they have a voltage regulator on the setup too.. could that be the problem.. has anyone else's acted up like this before? id appreciate some info.. thanks
Supercharged 89'/ 85' SVO
11.945 @ 119.6
The speedometer problem is not going to be an electrical issue on an 88. A worn cable is a likely problem and can cause the gauge bob up and down.
On the oil gauge, I would first replace the sensor first, before moving to other parts.
![]() Supercharged 2.7L 398 HP 501 ft lb !! |
Best first question is have you checked the oil? mine used to twitch when it got low
1991 Mustang LX 2.3L 5 Speed convert 1989 Ranger 4X4 2.3L 5 Speed Entire turbo kit waiting to be used again. |
1988 mustang 2.3L
I have a 88 also...and had same issues....
-speedo would jump around like crazy...had cable replaced..if your doing yourself here is good article on how to access it Fox Body Mustang Tachometer Replacement - Mustang Monthly Magazine -oil needle will probably be sensor |
i check my oil level about every two weeks because the motor is in need for a gasket set because it tends to leak alittle bit out of the oil pan.. the guage has been twicting about everyday for the last month lol so im pretty sure the sending unit is shot..ive put all of my trust into this car which i havent to any other car before.. shit i even drove it home from work when i didnt check the antifreeze mixture on a cold michigan winter day and the only reason the car quit was because the radiator was starting to slush.. didnt crack the block,head,or radiator and still driving the hell out of her lol..
Threads Similar to: instrument cluster problems...
| instrument cluster?? | dah | 5.0 Mustangs | 10 | January 6th, 2011 08:12 PM |
| Instrument Cluster | tarpeeler | 2005 - 2010 | 8 | October 28th, 2009 03:48 PM |
| instrument cluster | ty | General Tech | 0 | April 1st, 2007 12:17 AM |
| Instrument Cluster | Euroeater95 | 94-95 | 3 | December 3rd, 2006 01:16 AM |
